General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
climate control bulb
Old Oct 31, 2010 | 10:11 AM
S.Skinner's Avatar
anyone know what size/designation this tiny bulb is behind the climate controls on my 88 4runner? thanks in advance!!!
Old Oct 31, 2010 | 10:36 AM
xxxtreme22r's Avatar
if I remember right it's a 74. why not just take it out and take it to the parts store? or is it completely missing?
Old Oct 31, 2010 | 11:02 AM
Philbert's Avatar
I believe that's the one, yes. I took mine out to the store and that was the best way to confirm it was correct.
To get to it, be careful....take the knobs off the slider heat controls, then using a small flathead, CAREFULLY pry the edges off the bezel that has all the controls printed on it - pry near where that meets the digital clock....should pop off. There is a clear piece of plastic behind it, and the bulb is behind this...it illuminates the entire display .
While you're at it, replace your dash bulb lights - see my DIY on it
Good luck - go slowly so you don't break the plastic!
Old Oct 31, 2010 | 01:53 PM
S.Skinner's Avatar
I replaced my dash lights with led, but cant find a size for the climate bulb to order the correct led.
Old Nov 1, 2010 | 05:29 AM
richf's Avatar
http://www.superbrightleds.com/cgi-b...ini-wedge.html
This site has what you need. The 194 are for the big bulbs in the gauge cluster and the 74 are the small blubs in the cluster and climate control panel. I bought the 194 90 degree bulbs for the gauge cluster and think I should of gone with the 120 degree. The 90 degree 74 work just fine in the climate control and gauge cluster.
Old Nov 1, 2010 | 06:37 AM
S.Skinner's Avatar
Yeah i actually went with the 360 degree 194, turned out pretty nice, MUCH better then the dingy green. ok, so a 74 it is then, Thanks!!!!
Old Nov 1, 2010 | 06:57 AM
hey skinner, post up some photos of your led swap, I wanna see what those 360 degree ones look like. Most of the ones on here are a little too focused for my liking. ie the 90 degree ones like richf mentioned. Oh and which ones you went with the xhp9, xhp13 etc etc
Old Nov 1, 2010 | 11:49 AM
S.Skinner's Avatar
will do, i'll grab the " good " camera tonight when i get home from work and get some pics. My camera phone doesnt do it justice
Old Nov 1, 2010 | 11:57 AM
richf's Avatar
I would like to see some pics of the 360. I bet it lights up the cluster the best. i'll post some pics of my 90 so we can compare.
Old Nov 1, 2010 | 08:19 PM
S.Skinner's Avatar
ok, got the pics, there too big to post here so ill figure it out tomorrow. the bulbs i went with are the WLED-xHP9-T
Old Nov 2, 2010 | 06:16 AM
S.Skinner's Avatar
Size:  39.2 KB 2 photos to see the new leds
Old Nov 2, 2010 | 06:23 AM
S.Skinner's Avatar
pics posted with the help of xxxtreme22r, ( im not to PC savy) Thanks xxxtreme!!!! Was also told that since i had to do a little alltering to get these bulbs to fit, i should explain what was done. After removal of old bulbs while i noticed the new bulbs wouldnt fit into the clear plastic light channel opening. I removed the guages from the cluster and opened the opening up a bit with a dremel tool. Put the guages back together with the lights installed and walah!!!
Old Nov 2, 2010 | 06:34 AM
they look really good. definitely not as spotty as the other non-360 degree ones. too bad the dimmer no longer works. they look really bright.
Old Nov 3, 2010 | 12:43 PM
richf's Avatar
Not the best pictures but you get the idea. 90 degree beam
I like the way the climate control looks but I think I should change the gauge cluster
Old Nov 4, 2010 | 07:37 AM
S.Skinner's Avatar
yeah, theres alot of glare in my pics, but in person it looks good, no dim spots
kawazx636
Oct 6, 2021 03:03 PM
4banginRunner
Nov 13, 2015 05:23 AM
kcaudill
Oct 10, 2015 02:39 PM
Scotttekoch
Sep 28, 2015 10:30 PM
toyotasaurus
Sep 24, 2015 03:30 PM
