Spark plug and wires recommendation
I just use the Toyota wires and plugs anymore.
I had so many problems with the after market wires I switched to Toyota wires and the problems went away.
The price is on par with a good set of after market wires.
to put in my 2 cents... I have a 93 v6 pickup. I had the napa lifetime warranty wires, and Bosch+4 plugs. I was having weird mis fire conditions, and a huge hesitation at lower rpms. I took it to multiple mechanics who never could figure it out. So I finally snapped and took it to the toyota dealer. The mechanic instantly started taking my plugs out and replaced them with stock ngk's and new toyota wires. He went with me for a test drive, and explained that he has seen this for years now. My truck has never ran better since. I will never buy anything but toyota stuff now. It just works.
Does Toyota use NGK wires too or just plugs?
Anyone have any experience with the new NGK Iradium Plugs?
http://www.ngksparkplugs.com/product...x.asp?mode=nml
Try to use the V-Power NGK plugs in our old tired engines if you can. The Iridiums will burn too hot for our engines (Unless you have done other modifications).
I Put in V-Power NGK Plugs Part #1233 and BWD Select Wires #CH5414
This is for my Gas Powered 22re btw
similar question.
my truck has 138K
with a battery intake swap
& a 2.25 inch exhaust
im going with NGK:
but should I go V-power or iridium
should I look at the current plugs to find out..?
my truck has 138K
im going with NGK:
88runnergomas
Jul 9, 2015 01:12 PM
really now toyota's only like ngk or denso
