I need a tie rod--i think ?!
Old Oct 13, 2010 | 03:41 PM
RIDE-N-HI's Avatar
i am in need of a tie rod is what i was told, but when i look at my auto repair manual, the tie rod is showing to be the end pcs to a long bar it attaches to.
the long bar that the tie rod is showing to attach to is actually what i am needing because mine is bent.
anyone know what it is called or where i can find one???
Old Oct 13, 2010 | 06:28 PM
99blackSE's Avatar
Does this help?
You bent what is referred to as the tie rod assembly?
edit; Nevermind, thought this was in the second gen forum.
Old Oct 13, 2010 | 07:05 PM
clydehatchet's Avatar
if its the 'long rod' connecting the left side to the right side assemblies, there are a few names. 'relay rod', 'center link', 'drag link'. just to name a few. it would connect the tie rods left and right, idler arm, pitman arm.
Old Oct 13, 2010 | 07:24 PM
4Crawler's Avatar
Assuming a solid front axle (from your picture) and stock push-pull steering, the tie rod connects the two knuckles/steering arms and the drag link connects between the one steering arm and the steering box. Stock drag link is straight, some aftermarket ones are bent:
Old Oct 28, 2010 | 11:16 AM
stock as possible's Avatar
Potential dumb question: I just picked up a SFA with hi steer already on it but the tie rod is bent some in the middle. Is there a tolerance that would allow me to keep it or is it a must that I replace the rod?
Old Oct 28, 2010 | 10:41 PM
peow130's Avatar
If you can't get the hubs within alignment specs, then toss it.
It's just a piece of DOM with the ends threaded.
Old Oct 29, 2010 | 03:17 AM
dropzone's Avatar
Fossilized
Like Peow said, just replace it. IMO if it is bent no way you will get it aligned.
main tie rod DOm at skys $100: http://www.sky-manufacturing.com/new...duct.php?id=62
All pro has one for $60: http://www.allprooffroad.com/pickupsteering/253
I did not see it listed separately on either T-G or Marlins site
Old Oct 29, 2010 | 05:59 AM
I think the Marlinks are marlins'. I'll probably go with the all pro as its their kit to begin with that's on the axle. Plus I believe the $60 one is the just the tubing, w/o the ends.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
beltcutter
Sep 30, 2015 06:14 AM
