180k Refresh
Old Oct 6, 2010 | 06:18 AM
gdutch's Avatar
180k Refresh
Well, my 4Runner is about one oil change away from hitting 180k, and I want to perform a full maintenance baseline. I got it at 130k and I just want to replace a lot of the standard items so I can know how long they've all been in there. Here is my list of things to do, let me know if I'm forgetting anything:
Fluids
-Transmission flush and fill
-Oil
-Coolant flush and fill
-Power Steering
-Brake
-Differential
Belts & Hoses
-Timing Belt & Water Pump
-Accessory belts
-Coolant hoses
-New tranny cooler hoses
-Close off bottom of rad (former transmission hookup)
-Air Filter clean (K&N long life filter, will be around 50k on it)
I don't need plugs as those are fairly new. Am I forgetting anything?
Old Oct 6, 2010 | 06:25 AM
vital22re's Avatar
totally a bro
pcv valve, fuel filter
Old Oct 6, 2010 | 06:53 AM
gdutch's Avatar
Fuel filter was replaced not long ago. PCV is a good addition.
hross14's Avatar
At 180K i would replace:
**02 sensors
**TPS
**Clean & Test the injectors
**MAF--If you got the dough or buy a back-up (crashed vehicle)
**Check rear Wheel bearings
**Plug Wires--Or OHM them
**Fuel Filter
**Various (Front of Engine) idler bearings including fan idler bearing
Thats about all I can think of--and for the record, i am a little more premptive at maintenance than most--maybe do all those things at 200K
Old Oct 6, 2010 | 08:13 AM
TheDurk's Avatar
Thermostat when you do TB, water pump, hoses and flush and fill on coolant.
Check rack bushings, tie rod ends, sway bar bushings, end links.
Old Oct 6, 2010 | 09:00 AM
Elton's Avatar
just get a whole t belt kit comes with everything plus new fan belts and rad hose for $300 bucks
http://cgi.ebay.com/ebaymotors/Timin...Q5fAccessories
Old Oct 6, 2010 | 09:47 AM
hross14's Avatar
OH--upper and lower Ball joints
Old Oct 6, 2010 | 09:50 AM
brian2sun's Avatar
Have you considered doing an induction cleaning? I did a Motorvac service on mine earlier this year (~197K) and it really breathed "life" back into my motor. It runs better and has more power than it has had in a long time. My mpgs went way up and have stayed there too (seriously, almost a 50% increase from ~11 - 16). I will be doing this at every tune up from now on for all my vehicles.
Old Oct 6, 2010 | 11:43 AM
Deceptiwave's Avatar
Brian, what's this MotorVac service?
Old Oct 6, 2010 | 01:27 PM
gdutch's Avatar
I Seafoamed it not long ago, haven't had any issues with my mileage. O2 sensor was replaced ~500 ago after getting shredded somehow. BJs are a good idea.
SubiKing
Aug 21, 2021 03:57 AM
dzldust
7
Oct 6, 2015 05:39 AM
94toyy
12
Sep 14, 2015 06:18 AM
--Oz--
Sep 6, 2015 01:06 AM
4runnerjunk
Aug 22, 2015 09:06 AM
