Transfer case lift? Your ideas.
Hey guys I got my 7mge swap done in my toyota pickup. Im having a issue with the intake hitting the break booster. I did dent the booster about a 1/4 inch but dident want to beat it up to much. What do you guys think about building a spacer to lift the transfer case a inch or two so it will push the engine forward just a little bit to make the intake clear the booster? See when using the 5mge motor mounts ( engine side) it puts everthing at a 10 degree angle. Is there any affects of lifting the transfer case enought to gain some clearence?
Block of steel. It isent much drive lines dont bind at all. With the 5mge motor mounts it puts the drive train at a negitive angle of 10* so a little bit of lift on the transfer case is ideal when you got a 7mge engine swap!
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
Dec 27, 2016 01:58 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
yourrealdad
Jul 29, 2015 11:08 AM
crashburnoveride
Jul 10, 2015 06:39 AM
