93-98 T100s All T100 trucks
T100 Tire rub 31x10.5
Old Sep 24, 2010 | 11:16 AM
kevtek's Avatar
I have a 95 T100 sitting on 31x10.5x15 BFG AT on 15x8 Procomps. No lift
I've done some searching but threads on T100s are pretty slim.
I'm kinda new to these types of mods, as I do not do any heavy wheeling with my truck. Toyota's stock setup gets me everywhere I need to go.
So my front tires are rubbing on the plastic mud flaps at full flex and cranked steering.
I thought I would just cut that portion of the flap and pound in the metal but it is fairly close to the body mount.
Any ideas how to reduce rubbing without lifting the truck? Would pounding this area in result is anything negative? Would spacers help? Should I simply allow the tires to tear through the flaps and hope they don't hit the metal?
Thank you and please forgive my greenness.
Old Sep 25, 2010 | 12:30 PM
Cowyja's Avatar
Same problem here and i think i am ging to body lift or cut not sure yet
Old Sep 26, 2010 | 06:35 PM
BoredOutnJackdUp's Avatar
Take off the front mud flaps and add some wheel spacers.
It will fix it i promise.
Or take a hammer or saw to where its rubbing.
Nothing bad will come from it except if you dont like the looks.
Old Sep 29, 2010 | 04:50 AM
Zuke79's Avatar
I have the same tires/size on my stock 15X7 alloys and they have plenty of clearance.
Old Sep 29, 2010 | 06:04 AM
250000_yota's Avatar
are the rim's your running stock? my T100 came stock with 265/75R16's, which is a 31 inch tire, and i've never rubbed on the fenders. just on the sway bar after i put the bj spacers on...
-edit- just read signature. check the backspacing on the rims. stock is 3.75 if i remember right (someone correct me if im wrong...)
Old Sep 29, 2010 | 06:45 AM
Yopar's Avatar
IMO stock Toyota rims are the answer to fitting tires w/ no lifts, we're running 255/85/16 (33") on stock aluminum Toyota 16" rims and they fit with no lift, mudflaps removed. I think the 16" rim came as an option on 97-98 T100, and 15" was standard from 93-98.
My suggestion is to measure and compare the backspacing on your rims to a set of stock Toyota rims, regardless if they are cast aluminum or steel and see if you can pick up a set. This would relieve you of beating your truck up and cutting things off.
Old Oct 26, 2010 | 06:33 PM
rayrb1216's Avatar
take off the mudflaps, 10 or 12 mm i forget
Old Oct 26, 2010 | 07:27 PM
kevtek's Avatar
I'll have to look into spacers. Not too worried about looks, its a truck not a piano.
I'd really like to keep my 15x8 wheels on the truck. The procomps are nice and were free with my old 86
They other day I took a hammer to the steel underneath the flaps. Looks much better on the driveway. I'll have to get it in the woods to check under flex.
Old Oct 26, 2010 | 09:28 PM
survivorman97's Avatar
I don't know what kind of wheel spacers you are looking for but I have a pair that will bump your wheels out 1/4 inch that are for sale. Just pm me if you are interested. I would also have to vote for just taking off the mudflaps and finding a less intrusive brand and slap them on
Old Oct 28, 2010 | 08:51 AM
kevtek's Avatar
Took the flaps off and took some poser shots. I'm working in the woods tomorrow, I'll do a real test then. This isn't full flex but it gets pretty close.
Album Link(10photos)
I might end up pounding in the foot rests. I'll update tomorrow.
Old Oct 28, 2010 | 10:31 AM
yoder519's Avatar
yea id just pound it flat. but make sure theres nothin in behind it that could get damaged
markwink
Aug 18, 2015 12:38 PM
94ofCanada
Aug 14, 2015 06:37 AM
coffey50
Jul 28, 2015 10:55 AM
Cabell
Jul 24, 2015 12:14 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
