Cold Air/Supra AFM Mount (dial-up beware)
Old Aug 21, 2010 | 06:23 PM
irab88's Avatar
so when i went to install my ebay finds, i found that the included hardware didn't support the bulk of the supra afm too well, so today i decided to make my own. it's probably strong enough to make into a tow point. enough blabbering, and now for something completely different:
PICTURES (why you clicked to begin with)
http://www.flickr.com/photos/ianrab/4914307965/http://www.flickr.com/photos/ianrab/4914304803/http://www.flickr.com/photos/ianrab/4914305237/
^before
http://www.flickr.com/photos/ianrab/4914908922/http://www.flickr.com/photos/ianrab/4914305409/^a must. i can't count the number of times these have saved my vision
http://www.flickr.com/photos/ianrab/4914306399/^first piece
http://www.flickr.com/photos/ianrab/4914909520/^a hack saw worked sooooo much better than the dremel
http://www.flickr.com/photos/ianrab/4914909722/^first hole drilled. the wrong way. the bolts bump into each other
http://www.flickr.com/photos/ianrab/4914910126/^the right way to drill adjacent mounting holes. no bumping
http://www.flickr.com/photos/ianrab/4914909922/http://www.flickr.com/photos/ianrab/4914306787/http://www.flickr.com/photos/ianrab/4914306589/http://www.flickr.com/photos/ianrab/4914910944/http://www.flickr.com/photos/ianrab/4914911380/http://www.flickr.com/photos/ianrab/4914307223/http://www.flickr.com/photos/ianrab/4914912280/http://www.flickr.com/photos/ianrab/4914307771/^check for clearance. probably should have done that to begin with. oh well
http://www.flickr.com/photos/ianrab/4914308147/^after
just goes to show what someone without a welder and grinder can do
Old Aug 21, 2010 | 06:30 PM
BigBluePile's Avatar
Looks good...
Old Aug 21, 2010 | 06:36 PM
irab88's Avatar
now all i need is a box and somewhere to run it
Old Aug 21, 2010 | 06:39 PM
box? Why?
Old Aug 21, 2010 | 06:42 PM
irab88's Avatar
i can't imagine that it's truly a "cold" air intake if it draws straight from under the hood, behind the radiator
Old Aug 21, 2010 | 06:48 PM
actually if you swapped the battery and intake around it would be a lot cooler...
Old Aug 21, 2010 | 06:50 PM
irab88's Avatar
i know, but the a/c hoses are in the way
Old Aug 21, 2010 | 07:04 PM
You cant make a flex hose to go over?
Old Aug 21, 2010 | 07:12 PM
kiyobrown's Avatar
I have a/c, and I made it work.
Old Aug 21, 2010 | 07:16 PM
A.Wilson013's Avatar
Here is a picture of my Supra AFM.
Old Aug 21, 2010 | 07:17 PM
irab88's Avatar
i don't know why i didn't think of that before. ha. now to read up on the a/c system
Old Aug 21, 2010 | 07:19 PM
haahahhahhaHAHA!! Yup, I see it!
ah yeah...
Old Aug 21, 2010 | 07:22 PM
kiyobrown's Avatar
Logan's is hiding behind yours, But I see mine in the background, too. Almost a three-fer!
I was even able to build a partition to keep the majority of the underhood heat away from the intake.
Old Aug 21, 2010 | 07:26 PM
I recommend the Kiyobrown intake seperation swaperooo mod, ftw
I'd search for a link...but Im WAAAAAAAAAAAAAAAY too lazy...
Last edited by BigBluePile; Aug 21, 2010 at 07:27 PM. Reason: not posting link...:roll:
Old Aug 21, 2010 | 07:32 PM
irab88's Avatar
hey jason, do you have any pics of your setup?
Old Aug 21, 2010 | 07:59 PM
kiyobrown's Avatar
Well, here were my choices on where to put the partition. Only reason I threw it in was so you can see the setup a little better.......
And here is the finished product. Some old metal shelves, tin snips, rivets, and peel and seal (poor man's dynamat)
I tried looking for a link, I must have posted it in the bumper thread, or the friend bank thread, or the snow run thread. Who knows, but I never made a separate thread.
Either way, I still haven't sealed the top of the box against the hood. But it still gets air thats only 5 degrees warmer then ambient air. I'll take it.
Old Aug 22, 2010 | 12:11 PM
muddpigg's Avatar
Nice setups. Like the mount.
Kiyo, where'd you get that filter. I have a taller one that's size would prevent this set up.
BBP/Kiyo: when you move the MAF to the battery location is there any special methods for elongating sensor connector? Yes I've been here long enough to search but am lazy. Thanks.
If I ever get time again to wrench. My dang truck isn't even trail ready now. With no idea when I'll ever get the time reduce my "todo list."
Old Aug 22, 2010 | 01:11 PM
kiyobrown's Avatar
Scott, it's an autozone "spectre"'special. They had a couple sizes. This one allowed for more of a sweeping 90. Although eventually I would like to get something non corrugated. But I am pretty sure my 196k mile motor wouldn't notice the difference.
My special method was cut and splice, and try not to screw up the wires.
Old Aug 22, 2010 | 01:18 PM
Hey Mudd!!!!!!!
whatdya mean your rig ain't ready to wheel?!
fer sure man, mine as well is the Spectre special, but is a much larger version of Kiyo's. I got some good high quality weather proof splices and cut one at a time. Next time I'll cut the wires at different lengths so not to have one giant LUMP of splices. Also, you'll have to extend a main power wire too.
Old Aug 22, 2010 | 03:41 PM
muddpigg's Avatar
BBP: I burned up the Hayden controller for my fan, the automatic part. Think that dang flexalite is jinxed. Got a taurus fan to put in. Need to order the controller components I want. And of course the time to install. Want to pull the rear dif and swap in the ARB weld on some axle armor and shock mounts while I got the axle broken down. Got a ton of cosmetic stuff to do.
