Putting a factory roof rack on a 4Runner.
So, My truck was cursed without the factory roof rack. i've looked at my options of getting a roof basket on my truck but it would have to be mounted way up front. I don't generally like the look of that but if need be, that's what i'll do. But how hard would it to pull a factory roof rack off a 2nd gen 4runner ( or even off a 3rd gen? ) and bolt it to the roof of mine? are they trussed or braced on the inside above the head liner? I haven't really looked at it yet, but it seems like it would be a simple bolt on through the roof of my truck, correct?
roof rack
You have tons of options here. I used to install permanent roof systems on 4 runners. Typical installation (in my opinion, the cleanest, most versitle setup) would involve drilling into the roof - although not through cross members - we used nut-inserts, a type of rivet that is threaded to fix aluminum track sections front to back on the vehicle. A consideration here is whether or not you have a sunroof - if you do, your track length will be limited. Yakima makes aluminum sections of track and sells hardware and end caps for installation. Super easy to install yourself - just measure correctly!!
Once you have track installed, then you can choose your bar rack from there - adding more bars for additional weight etc.
Check out: http://www.nextag.com/yakima-track/search-html for a visual. (top item)
Good luck!
Good luck!
i would find one at the yard and pay no more than 20 bucks and screw it to your roof, easy as pie, just make sure you use a rubber strip underneath or those screws with rubber washers, or something to keep water from getting in
If i was you, i would go to one of the pic n pulls by you and see if you can find a second gen 4runner with a roof rack and pull the head liner down and see how its mounted and braced through the roof. That would give you an idea of what you need to do.
Let us know how it goes...I have a 2000 5speed w/ no rack and also looking to go the factory rack route. I have surf a couple salvage yard but did not like the condition of the racks.. With this generation the no rack option has a cover where the track rails would go it appears to be easy....too easy.
a factory rack has been done, i just wanted something full size.
the 4Runner has been sold.
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
