Sponsored by: CARiD
1981 toyota 4x4 leafspring separarted from frame HELP!!
Old Jul 18, 2010 | 01:02 PM
828_hinson's Avatar
1981 toyota 4x4 leafspring separarted from frame HELP!!-marks-cell-phone-pics-037.jpg
Old Jul 18, 2010 | 01:24 PM
myyota's Avatar
It looks like you need to replace that frame as soon as possible, I wouldn`t even try and repair that.
Old Jul 18, 2010 | 01:28 PM
828_hinson's Avatar
Ya this sucks how does one find a frame that will work?
Old Jul 18, 2010 | 01:30 PM
waskillywabbit's Avatar
Try a junkyard, Craiglist, local paper, etc.
Old Jul 18, 2010 | 05:17 PM
828_hinson's Avatar
Will a 1987 4x4 frame work on my 81?
Old Jul 18, 2010 | 05:34 PM
xxxtreme22r's Avatar
no your 81 is solid axle the 87 is IFS. not sure on the back half
Old Jul 18, 2010 | 05:35 PM
BTW if you look at my build thread, you will see I had mine repaired in that same spot. but by the looks of the rail behind it, that frame doesn't look too good.
This is the second frame thread in like a week here too.
Old Jul 18, 2010 | 05:47 PM
828_hinson's Avatar
The frame is good just in that one spot by the gas tank is bad I didnt know it was this bad till today,a little off roading proved me wrong.
Old Jul 18, 2010 | 05:50 PM
when the guy who repaired mine put the truck on the lift the whole spring mount fell off. Cost me $350 to have him do both sides. He did not have to drop the tank.
Old Jul 18, 2010 | 06:14 PM
MAINETOY's Avatar
Seperated rear spring mount
hey extreme,if the guy that repaired yours didnt pull the gas tank than he did a subpar job.tank should have been pulled and inner frame boxing removed,cut rust out and plate from inside.i have seen many butchered frame repairs.i have repaired many and you dont take shortcuts.just my 2 cents worth.anything is fixable but dont waste your money unless you do it right.
Old Jul 18, 2010 | 11:30 PM
wyoming9's Avatar
Red face
Well without seeing the frame up close it is hard to make a call about repairing or replacing .
It might be nice if people told us where they were from.
I agree about the fuel tank but if there was no reason to remove it why add the extra labor to the bill . I have done it both ways and would not say it was a subpar job in either case.
If one had the place time and skills you could splice a rebuilt frame in under the cab somewhere. Unless your in the Southwest the chances of finding a good used frame are not good unless it was stored inside someplace
Old Jul 19, 2010 | 03:41 AM
I'm in pa, so finding a back-half is pretty much non existant, the guy that did my frame has been working in a leaf spring shop for longer than most of us on here have been alive. He has repaired many toyota frames the way he has on mine. And well lets say, two winters now with it and a good pounding on the trails, it's holding up just fine. Oh BTW he used like 3/16 plate to repair the cutouts he was able to make. I would think it's actually stronger than the what 1/8" if that of a box.
Old Jul 19, 2010 | 05:19 AM
84foyota's Avatar
Looks like you need to do what I did. Box the entire back half of the frame. See my website for details
www.funfactorfab.ca
Old Jul 19, 2010 | 04:06 PM
828_hinson's Avatar
Oh i'm in eastern tennesse
6th Gear
19
Dec 10, 2019 07:31 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
crash
21
May 28, 2005 10:11 AM
Corey
24
Jul 15, 2002 07:53 PM
Krash
10
Jul 13, 2002 09:21 PM
