Pre 84 Trucks 1st gen pickups
Spacers
Old May 25, 2010 | 02:41 PM
Nimyad's Avatar
Spacers
so i'm goin to switch in the wider rear axle (i need spacers up front cause i hit the leaf springs and box when turning) so i'm goin to match the width up front. so my bud told be you can take stuff off an ifs and replace parts of the live axle instead of using spacers and you'll still gain 3 in total width. has anyone does this? what all do i need from the ifs?
Old May 25, 2010 | 02:49 PM
xxxtreme22r's Avatar
sounds like he's talking about using the rear end from an IFS truck as the front axle. Doable? IDK, anything is possible with the right tools, knowledge and fab skills.
Old May 25, 2010 | 03:07 PM
Nimyad's Avatar
no he was saying you can take the outer assembly from an ifs and put your stock hubs in it and run it on the original solid front axle.
Old May 25, 2010 | 03:40 PM
slacker's Avatar
yes .. the 86-95 IFS hubs are interchangeable ... and wider .. and match the width of the 86-95 rear axle housing ..
Old May 25, 2010 | 03:43 PM
Nimyad's Avatar
ok. so i just get the ifs hub assemply. do i run those calipers and rotors or what?
Old May 25, 2010 | 03:49 PM
slacker's Avatar
bolt pattern is the same .. so all of your old parts will work ..
i might suggest the up grade though ..
Old May 25, 2010 | 03:52 PM
Nimyad's Avatar
like the v6 calipers and vented rotors? if i pull ifs hubs from a v6 pickup isn't it the same thing.
Old May 25, 2010 | 05:34 PM
slacker's Avatar
yes vented landcruiser rotors and V6 IFS calipers ..
IFS truck rotors are not vented .. they are solid
I have them on mine .. check out my current build in my sign.
Old May 25, 2010 | 07:00 PM
Nimyad's Avatar
ok. thank you. trying to decide if it's better to do all that or just get spacers
Old May 26, 2010 | 06:29 AM
slacker's Avatar
spacers are what ? $65.00 and about 1/2 hour to install ...
Old May 26, 2010 | 06:37 AM
waskillywabbit's Avatar
All this is detailed in several threads on here as well as the Pirate Toyota FAQ.
Old May 26, 2010 | 03:50 PM
Nimyad's Avatar
ya but i want to do it the right way and the stronger way so that's why i was looking into this
Old May 26, 2010 | 03:53 PM
SpecialScottie's Avatar
So whats the point of buying the sky kit if you can just use IFS hubs to gain the width?
Old May 26, 2010 | 04:02 PM
Nimyad's Avatar
i would imagine it might be easier but parts from a junkyard would be a lot cheaper and probably worth the extra effort
Old May 27, 2010 | 09:51 AM
dropzone's Avatar
Fossilized
using the IFS parts to widen the front SA is not just slapping the parts on:
http://www.sky-manufacturing.com/new...uct.php?id=127
http://www.pirate4x4.com/forum/attac...postid=1649941
http://www.pirate4x4.com/forum/showt...9&page=1&pp=25
http://pirate4x4.com/forum/showthrea...15#post2423615
some of this should help you out
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
crash813
Sep 27, 2015 07:15 AM
