stuck on steering rag link ext. for body lift
Old Nov 19, 2003 | 06:02 PM
INsr5runner's Avatar
hey I'm stuck at the steering rag link. how do I get those bolts off?? i PB blastered it, and tried a breaker bar.. maybe I'm just not strong enough?
what did you guys do to get it off? I need to slip my extension in there!
Old Nov 19, 2003 | 06:05 PM
waskillywabbit's Avatar
Re: stuck on steering rag link ext. for body lift
TWO WORDS........
AIR TOOLS!
Old Nov 19, 2003 | 06:08 PM
AznSky's Avatar
I just think ur a wuss....
Old Nov 19, 2003 | 06:09 PM
4 words....
WISH I HAD SOME! :cry:
Old Nov 19, 2003 | 06:10 PM
aha
...but a smart wuss!
Trade beer for use of air tools!
Old Nov 19, 2003 | 06:11 PM
4runner4me's Avatar
If you are talking about in the steering shaft where you put the spacer in. If so I could not get the bolts off with the nut at the bottem. I just took the upper nuts off. The with the lift it pulled rite apart.My spacer only had to bolts to replace two of the stock bolts stayed unmoved.
Old Nov 19, 2003 | 06:14 PM
Seriously, if you have already lifted it with that steering extension tight the whole time it might be in such tension it ain't coming off. I loosened mine before I ever started lifting.
Old Nov 19, 2003 | 06:15 PM
Re: Re: stuck on steering rag link ext. for body lift
wait, you only took 2 of the 4 bolts off? how did you stick the spacer in between?
Old Nov 19, 2003 | 06:17 PM
Re: Re: Re: stuck on steering rag link ext. for body lift
There is a bunch of junk up there in the steering area where you are to put the extension. We took out the whole assembly, what I mean is we pulled the splines apart and then put the spacer in the top part after we took it out using just those two bolts, I think, and put in the two longer bolts with the spacer, then lined the splines back up and wala!
I actually haven't put the lift in, we called it a night, because we had to take the bumper/winch off to get at the front body mount. seeing as it is 10 now, we probably wouldn't be done until 12, or so, and my friend has a test tomorrow he needs to study for.:cry:
I was just trying to get it off after he left, and couldn't
so I pb blastered it some more to see if that helps tomorrow
Old Nov 19, 2003 | 06:21 PM
waskilly, do you have a better pic of the steering ext. by any chance? the one on 4crawler.com is a little blury when you enlarge it...
Old Nov 19, 2003 | 06:24 PM
Sorry
Nope, didn't take any pics when I did the mod. I will take some when I take it off.
Old Nov 19, 2003 | 06:29 PM
Re: Sorry
In Roger's pic, you see the two new shiney bolts that he has going through the steering extension, I took the other two loose and removed the whole thing from the spline, took out the whole little assembly and on the work table removed those other two bolts, put in the steering extension and the new bolts, put it back on the spline and then bolted it back together.
Old Nov 19, 2003 | 07:29 PM
4runner4me's Avatar
It pulled in two peices after I lifted it. I was 2 bolt that just poke though. Just 2 bolts are replaced.
Old Nov 19, 2003 | 09:33 PM
keisur's Avatar
if you can get a brass bar in there and tap the bolt head a couple times with a ball pein hammer, not hard like you're trying to mangle it, just a couple good solid taps like you do when the jelly jar lid is stuck on. that may bust her loose without the need for air tools. good luck dude.
Old Nov 20, 2003 | 06:21 AM
thanks... its hard because the steering wants to turn when I twist the nut
Old Nov 20, 2003 | 07:02 AM
keisur's Avatar
isn't the steering lock engaged? it should only go a few degrees if it is.
Old Nov 20, 2003 | 09:06 AM
maybe this is a dumb question, but how would I engage the steering lock?
Old Nov 20, 2003 | 09:10 AM
runningman's Avatar
2c
try turning your wheel while the ignition is off and the key is out of the tumbler, it should lock after a few degrees.
Old Nov 20, 2003 | 09:57 AM
keisur's Avatar
Re: 2c
yea, what he said.
Flying91
45
Apr 11, 2024 04:39 PM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
