Serious Problems Here! 22re Will not idle
I have a 1986 Toyota 4runner with the 22re. I had a leaky injector (but still ran and idled perfect just popped a little bit) so i went through and replaced all of the top gaskets on the injectors. This caused it to leak worse and not run at idle at all. If i kept it on the gas it will run ok.
So i got an entire gasket kit for all of the injectors took them out and replace all of them put it all back together and it ran the same, bad unless at quarter throttle. We listened to the injectors and 1 and 2 were not firing as well as double checked it by pulling plugs. when 1 and 2 were pulled it did no change in condition. if 3 or 4 were pulled it would die out.
So i drove 300 miles for 2 new injectors. put them in and turns out WE HAVE NO CHANGE!!!!!!!!!! I am about ready to lose it scrap the 4runner and cut my losses. SOMEBODY HELP!!!!!!!!!!!!!!
Thanks
Ben
:b ang:
Thanks
Ben
:b ang:
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
Jnkml
Jul 6, 2015 01:20 PM
