Truck won't start after jump
Old May 6, 2010 | 07:57 PM
heyguyswaitforme's Avatar
Long story short I jumped my 98 4runner, but thinking back i connected the positive first. Now I get nothing. Replaced the battery. I checked all the fuses and found that the EFI was blown. Replaced that; now I hear the pump working, but no radio no locks, windows or dash, headlights do work though. Any thoughts would be greatly appreciated.
Thanks
5VZFE
Manual
Old May 6, 2010 | 08:03 PM
PismoJoe's Avatar
Hopefully you didn't blow something in the ECM...I would pull it and start checking resistance between terminals, or you could just smell it ha if it smells burnt, no dice.
Check the FSM for proper terminal readings of the ECM
http://www.ncttora.com/fsm/index.html
Old May 7, 2010 | 02:47 PM
brian2sun's Avatar
Did you test your old batery to see if it was shot for sure? It might be corroded cables/wiring.
Old May 7, 2010 | 02:51 PM
PismoJoe's Avatar
I don't think that some electrical components would be working, while nothing is coming from other components if its just a bad connection.
Good idea though to hit those connections with some baking soda and water to get the corrosion off of there!
Old May 7, 2010 | 04:26 PM
scottishb's Avatar
A bad connection heats up. Heat equals resistance. Resistance equals voltage drop. Try to start and then feel the connectors. Are they hot? Things like headlights and pumps still sorta work on low voltage. The stereo and power windows probably wont.
Old May 8, 2010 | 06:39 AM
team_gforce's Avatar
Had a similar situation many years back. Battery went dead, replaced it with one from the local napa, and strange things were happening. Some things worked and others didnt. Turned out that the battery napa sold me had some cracked plates inside. The brand new battery was that last thing I would have suspected.
Old May 8, 2010 | 09:19 AM
DailyDrive's Avatar
It's a myth that this can damage anything.
Old May 8, 2010 | 09:54 AM
yotaman85's Avatar
make sure the cable from the positive terminal to the fuse box is not broken.. and while your at it upgrade it. make sure your grounds are still good also.
https://www.yotatech.com/forums/f116...er+supply+wire
Old May 11, 2010 | 02:43 PM
Under further investigation i discovered that the 100A fuse was blown. Now unfortunately trying to replace it i lost the screws that hold it in. So with a new starter relay and new fusible link hopefully she'll fire right up.
Crazychris1871
Jun 27, 2016 10:38 AM
newzingo
Jun 24, 2015 01:50 PM
slider417
Jun 22, 2015 10:18 AM
paxanders
Jun 21, 2015 06:29 AM
Corey
Jun 10, 2002 04:23 AM
