My Tranny Cooler Install (With Pics!)
Old May 5, 2010 | 08:00 PM
gdutch's Avatar
Recently finished (re)installing my Tru-Cool 4454. Previously I had bolted it on from the bottom of my 4Runner, where the skidplate bolted on. After discovering that I couldn't reattach the skidplate without severing the ATF lines, I realized I would have to remount it. Unfortunately, I had to wait about three weeks til I had time to attempt it again, but it was surprisingly easy once I found out the right way to remove the grille (the clips should be pressed from the inside with a flat head screwdriver, not from the outside )
Here you can see that it's dirty from the previous low mounting. These two brackets were able to hold it fairly flush against the AC condenser, although if I ever pull the radiator I'd like to put a ziptie through on the right side of it.
Another shot of the mounting. The send line goes in the top and out the bottom, according to MtGoat's recommendation in another of the myriad 4454 threads out there.
This is to try and show how the hoses are coming through, they use the same hole that the freon lines do coming out towards the front of the truck.
This one's a little confusing. The fan is there in the bottom left of the pic, so the front of the truck is towards the upper left corner. I'm trying to show the connections I made to the old tranny lines, behind the hole they come through to get to the front where the cooler is mounted.
Final shot of the whole setup.
I'm really glad I remounted it; when I did it the first time, it was mounted so low that I don't think it got sufficient air flow. After draining for this attempt my ATF looked somewhat burnt, so I really think it was a good idea to put it back up high with the fan pulling air through it all the time. I drove about 2,000 miles on it in the previous setup (in three weeks.)
Hope these can help anybody who needs ideas on mounting. Happy wrenching!
Old May 5, 2010 | 08:46 PM
J2F42C's Avatar
You did a much better job the second time around....looks good. I'll bet the tranny thinks so too....
Old May 6, 2010 | 04:36 AM
gdutch's Avatar
Thanks, just wish I had a scanguage so I could see how hot it's getting. Just based on performance though, it seems a lot happier. Shifts are smooth, and my shift selector doesn't get as hot at the bottom.
Old May 6, 2010 | 05:41 AM
DailyDrive's Avatar
i spy a socket wrench from the 99c store
Old May 6, 2010 | 05:43 AM
gdutch's Avatar
Lol yeah, hand me down. Still gets the job done though. I have another 3/8 drive but I just grabbed the first one in my tool box.
Old Mar 28, 2012 | 01:02 PM
Luther Grimace's Avatar
Which line is supply and which is return coming from the transmission?
Old Mar 28, 2012 | 06:42 PM
kball's Avatar
here you go
Attached Thumbnails My Tranny Cooler Install (With Pics!)-transmission-cooler-lines-front-view-small-.jpg   My Tranny Cooler Install (With Pics!)-transmission-cooler-lines-small-.jpg
Old Mar 28, 2012 | 07:36 PM
Alright thanks. I'm guessing the cooler should have the supplied attached to the top and the return attached to the bottom.
Old Mar 29, 2012 | 04:40 AM
kball's Avatar
That's how I did it but you'll get many different opinions on that so it's just up to you.
Old Mar 29, 2012 | 07:12 AM
rworegon's Avatar
That how I did mine too and it's works great...not pushing against gravity that way.
Be sure to get the tranny cooler as close to the radiator as possible, so the fan pulls air through the cooler.
Old Apr 6, 2012 | 10:34 AM
I installed one last week before a 1000 mile trip. I used an Auto Zone cooler and some 300 psi pushlock hose from my local hydraulic store. I had my radiator out anyway doing the timing belt and I used the supplied zip ties to attach the cooler through the fins of the condenser. The install worked out very well and clean. I'm glad I did this instead of rebuilding a trans later
mskalmus
May 28, 2017 07:51 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Iceman4193
Jul 15, 2015 04:48 PM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
