MC 1600lb clutch
MC 1600lb clutch
I've never read about anyone running Marlin Crawlers 1600lb clutch kit so I just wanted to share my experience.
I just replaced my Marlin 1200lb clutch with a 1600lb. The MC 1200 lasted me about 35-40k miles (I'm not exactly sure, trucks undergone many changes in it's lifetime). The 1200 was great and I'd reccomend it! This clutch got used, abused and driven, it's as close to stock with some extra grip you can get. Nice soft easy peasy pedal.
I put in the new 1600lb kit last weekend and it's definetly different. Takes some getting used to and i can definitevly say if you're looking for a stock feel this isnt the kit for you. It's extremely grippy (daddy likey!
) but this in turn makes it easy to stall.
I've felt a centerforce, stock and a few others and gotta say Marlins 1200lb clutch adjusted properly at the pedal with a OEM Hydraulic system is your best performance/money/comfort bet.
But the 1600lb is the daddy if youre looking for massive grip action!
hope this helps someone in their clutch decisions...
stock clutch is the suxorz =)
) but this in turn makes it easy to stall.I've felt a centerforce, stock and a few others and gotta say Marlins 1200lb clutch adjusted properly at the pedal with a OEM Hydraulic system is your best performance/money/comfort bet.
It doesnt take much to wipe out any clutch when your under-geared and rompn in swampn which is what this particular saw most of it's 40k life. Hot spots on the flywheel and pressure plate is pretty much the main cause of the final slippage towards the end. It still had some meat left but not much before you'd be hitting rivet. The clutch face was smooth, ie the wear grooves were gone.
If you're just driving on the roads and not spending 8 hours abusing the crap out of it in the mtns, it'll last a good 80k I imagine.
i had a MC 1800lb clutch put in my 95 when i had my engine rebuilt a few months back. ill never buy another brand of clutch again. when it grabs, you better believe it grabs. its a bit stiffer, but i like a clutch thats kinda stiff personally. if your undergeared and runnin bigfger tires like me.... 4.10s and 35s.... then get a MC clutch. i was ridin the clutch all day wheelin a few weekends back and i couldnt even smell it burnin. and it still feels brandnew
I'm actually getting ready to upgrade to the 1200lb kit soon...
Glazing the mating surfaces is what really kills any clutch. But with the higher clamping force you slip less so it won't overheat as easily but if you're riding it trying to get the right wheel spin/speed try not to overheat it (when you finally do start smelling it) cuz then you're basically KO'ing the clutch's overall life.
Live n Learn on that one =)
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
