Think i need a new rear axle???
Guys
Found this today, im finding it difficult to find the parts over here so how much you guys think i'll pick up a rear axle housing for a manual 3litre turbo diesel for in the states???
Any help would be appreciated
I have one I might be able to give you if you want to see how much shipping would cost from 76227 in Texas.
yes, it started as a hole in the housing at the top so i was always weeping a bit of oil, then the big arm that is welded onto it holding a tension bar broke off, ive gotten it welded by two diff proffesional welders but has always broken again, then this large crack appeared the other day and covered a motorcycle i had on a trailer with my axle oil ;-) dont think it can be fixed so need a new one...
Desp, your a superstar.....who do you reckon i contact to get a quote for shipping? do you reckon its the same rear axle as mine?
$640 to ship it from texas to ireland, WOW.....didnt think it would be that much...would there be anyone else to try other than UPS?? would my rear axle be the same as one from a 97 hilux surf??
Can't weld it up then support it from the outside with some bracing?
The later model axles aren't the same as the older 79-95 axles. I believe the diff is different.
You might be able to make it work if you convert it to leafs and leafs on your 4runner. But the dimensions of the later model link in the rear are going to be different.
