Need help with my hitch wires
I learned all about this last year. Hopkins makes some inexpensive "black box" replacements and I recommend their LED 4 pin connector as you upgrade so at a glance at the hitch location you can see what functions are working and which are not. Search "trailer convertor" here or Google
okay from that other forum but it's on Yota Tech as well:
http://www.toyota-4runner.org/access...-pin-help.html
the hardest part of the whole process is all the trim removal of your interior to get to the black box. SO be sure before you tear it all apart that you visually check the wiring as it snakes up into the cargo area-could be as simple as a chafed wire coming out to the hitch.
Thanks eric-the-red I took the converter off and tested it and I was only getting power in but none out, so i will look into replacing it soon. Thank you Ron Helmuth i will take a look at those LED connectors.
My stock trailer module died, so I replaced it with the plug-n-play hopkins one. Super easy, no splicing necessary, as it uses all the same plugs as factory. Model 43415. Not bad for $32.
http://www.amazon.com/Hopkins-43415-.../dp/B0002Q7ZLO
could be on the passenger side for a 98-it's definitely on the drivers side on 99s however-
did you get this solved 98blackSR5? just curious if you figured it all out. Took me some trial and error....
yeah i did thank you, I tested the black converter box and it was getting power in but not out so it was bad, I just don't have the money to fix it yet.
FS[PacNorWest]: 1982 Toyota Long Bed Trailer
58rennur4
Aug 4, 2015 08:49 AM
defrag4
Jul 31, 2015 10:50 AM
