2in coil spring kit
2in coil spring kit
I have been looking around but cant seem to find a 2in rear coil kit. I have found the coils but i'm not sure if i only need the coils or will i need a brake line extender. Just want to know if i need a kit or just the springs.
Any help would be awesome.
OME( Old Man Emu) makes probably the best coil kit for the rear of a 4runner, you can get medium or hard rated coils depending on what your wanting to do. Hard if you plan on loading up the rear or towing with your rig. Want to make sure you get the shocks to go with it as well otherwise you will end up with a choppy ride. Shouldnt need brake line extenders or otherwise. This kit will give about 2.5 inch of lift which will reserect the rear end sag. coils cost about 85 - 90 each and the shocks run about 90 each as well
You will want to extend the brake line from the LSPV, I think thats where it is, but do you want your brake line getting snapped off?
http://www.jamesdeancreations.com/4r...ect.htm#Brakes
http://4x4puertorico.com/
here is the distributor for OME in your neck of the woods. as for extended brake lines i dont know
Flying91
45
Apr 11, 2024 04:39 PM
priest16
15
Aug 6, 2015 07:43 AM
