Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
FJ40 Start help
Old Mar 30, 2010 | 02:16 PM
75FJ40's Avatar
FJ40 Start help
Just purchased a 75FJ40. 117k. It has been sitting for 8 months outside in Southern California. It turns over with starting fluid help but stalls out. Could it just be bad gas? Any tips to get it going?
Old Mar 30, 2010 | 02:45 PM
bipolarandproud's Avatar
Drain any old gas out of the tank for starters .
Then ,refill it , see if your getting good fuel pressure to the engine .
I would also change the fuel filter .
Then try starting it after that.
Old Apr 2, 2010 | 10:29 AM
wardriver's Avatar
Pull the fuel line before the fuel pump. Drain the fuel out of the bowl by loosening up one of the two 12mm (horizontal) bolts on the front of the carb. Then you can dump a little gas in to see if it fires up.
Carb might be gummed up, fuel filter clogged/line or crappy gas. There is also a drain plug on the bottom side of the tank.
Old Apr 2, 2010 | 12:03 PM
75FJ40's Avatar
Well the truck is home...but It still requires gas being poured into the carb to fire up. Fuel filter seems clean and it runs like a champ once it starts. I was thinking of maybe using some Seafoam maybe because the carb is gummed up. Make sense? Any other advice?
Attached Thumbnails FJ40 Start help-p1010129.jpg   FJ40 Start help-p1010130.jpg   FJ40 Start help-p1010131.jpg
Old Apr 5, 2010 | 03:17 PM
FlyingLow's Avatar
Ya try the sea foam. Choke hooked up and working? You should see it moving if you have someone else operate it in the cab. They always need some choke to start when they are cold. Also are you getting a couple shots from the accelerator pump into the venturies before you try to start it? You should see some fuel squirt out into the carb.
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
