wich color has the tachometer wire in 4runner 99?
Old Mar 22, 2010 | 11:41 AM
jakov's Avatar
I installed a viper alarm with remote starter and I cant find the tachometer wire , somebody knows? how to find it cause the remote start keep starting the engine and doesnt stop, even if its running the motor,,, thanks alot
Old Mar 22, 2010 | 04:22 PM
jdmaccord6's Avatar
pin number A25, black and yellow wire
Old Mar 22, 2010 | 10:36 PM
jakov's Avatar
tnx alot
well i will check that wire tnx for your response laters
Old Mar 23, 2010 | 04:42 AM
profuse007's Avatar
I stop using tachometer sensing when installing w/ viper units. I stick w/ voltage sensing.
Old Mar 23, 2010 | 08:10 PM
jakov's Avatar
voltage sensing?
i use to have the same viper alarm in a camry/ but the intaller doesnt remember the color tachometer wire, but maybe youre right, so how do you do that? how do you find the voltage sensing? the 4 runner start but keep starting and make alot of noise when remote starting!! tnx alot
Old Mar 23, 2010 | 09:12 PM
Kerby J's Avatar
you can also locate it by the black wire on the diagnostic port under the hood thats on top of the engine thats the one i used when i put my remote start and alarm in and it works like a charm
Old Mar 29, 2010 | 02:46 AM
ahtub's Avatar
hey kerbyJ, can you snap a photo of where that wire is located at and post it on here? not quite familar with it. thanks!
Old Mar 29, 2010 | 08:05 AM
Kerby J's Avatar
no prob but it will b ltr on tonight bc i have school till like 8
Old Mar 29, 2010 | 06:05 PM
Kerby J's Avatar
this is the diagnostics port i was talking about there is a black wire that comes out of it and it is the tach wire
Old Mar 30, 2010 | 01:08 PM
rideexileex's Avatar
I pulled my cluster and tapped into the tach wire behind there - far better for a stealth install. I dont remember the color, but it was really easy to find with a meter.
Old Mar 30, 2010 | 06:14 PM
Kerby J's Avatar
yes that might work but all install books say to use the one from the diagnostic port bc it reduces the risk of damaging anything in the cluster which can happen very easily
Old Mar 30, 2010 | 09:33 PM
jakov's Avatar
I found the wire and now its remote start working ,,
the cable wire was the black one , the one in the diagnostic , nothing but black and now it works very well so thanks my friend :
Old Mar 31, 2010 | 02:30 AM
ahtub's Avatar
yeah the black wire in the diagnostic worked hella good. all you gotta do afterwards is use some of that black tube wrapping and it'll look so much better and clean.
and thanks again for the pic Kerby J.
if anyone out there need some help installing a viper 5900 remote start into a 97 4runner lmk. i just got done with mine today.
Old Mar 31, 2010 | 06:10 AM
Kerby J's Avatar
no problem man anytime to help out a fellow member
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
coryc85
Sep 9, 2015 06:24 AM
toyota32
Jul 6, 2015 05:42 PM
colinmil
Jul 6, 2015 04:03 PM
