HELP installing rear 4" Superlift in '93 4runner!!!
Hey guys, I am in the process of installing a 4" superlift in my sis's '93 runner. Ive got the old rear stuff all pulled out and want to put in the 4link upper and lower relocation brackets but I cant exactly figure out which one forsure goes where and how it mounts!!
The instructions have diagrams for the front IFS install, but no pics or diagrams for the rear.
Anyone have any insight as to how the brackets mount, OR just a picture or two of your superlift installed on your runner?? Pics are always super helpful for me
Also, do both the upper and lower brackets mount to the diff, or does one of them go to the frame?
Thanks!
Thanks!
My Jeep has leafs in the rear.....
It was just the location of the upper and lower link brackets I was wondering about. With a fresh head the next morning it all came together and I got them bolted in.
Now the coils are just being a bitch and dont want to seat into the top mount..
James
The Procomp 4" lift is almost identical to the superlift and their instructions have diagrams.
How thick is the metal making up the rear drop brackets as I want to make some for my truck, just don't know how thick to go ?
How do you like it? had it in for a while?
The rear is done, just have to make some new swaybar links as the guy i bought it off lost them...
Just started the front, pulling the CA's and all that. Lift is goin slow but getting done bit by bit with the busy schedule...
I've never wrenched on IFS before so it'll be a learning curve I guess....any pre-tips?
I'll have a look for ya.. prob about 3/16", we'll see.
Front-
install steering knuckle adapters
install left, right differential housing spacers
install left, right LCA drop brackets
install front differential support (carried over from OEM) to LCA drop brackets
install sway bar drop brackets
Rear-
R&R coil springs
Install panhard rod drop
ummm?
Rear-
R&R coil springs
ummm?
Front-
Rear-
R&R coil springs
ummm?
Rear-
R&R coil springs
ummm?
So you wouldn't bother to install the 4 trailing arm relocation brackets or the longer shocks, bumpstops, lsv bracket etc ?
Front-
Rear-
R&R coil springs
ummm?
Rear-
R&R coil springs
ummm?
Ha ha ha... Is there a question in there I missed? Or did you just post some bad directions for a 2" lift?
I measured the trailing arms brackets they are all 3/16"
Last edited by waskillywabbit; Mar 27, 2010 at 05:51 AM. Reason: Censor bypass removed
voiddweller
19
May 2, 2016 09:10 PM
cchinny
Jun 25, 2015 08:11 PM
Gene
19
Jun 3, 2002 07:07 PM
