Reman h2o pump. FIPG or use the paper one
so i bought a remanufactured toyota water pump from Napa. I notice it came with a paper gasket. Should i toss out the paper gasket, and use FIPG? Or the paper one?
thanks. i installed the new pump with out the paper gasket, and the FIPG in place. Torqued the bolts to 14lbs, should be good to go.
timing belt is the next thing on the list. found a super write up on the timing belt by the way.
http://www.toy4x4.net/timing_belt/index.htm
JookUpVandetti
Sep 30, 2015 08:58 AM
