bad bank 1 miss need help.. going crazy!!!
ok sooo
im sure its the passenger side because i unplug the 1,3.5 spk wires and it runs smooth.
started out only missing sometimes now its all the time
i have done:
comp test 120psi all around <i know its low but its there all that low>
and i have checked spark and cam timing
no MIL
new
cap, rotor, wires, plugs,
i need help bad i have already pulled the valve covers off and im wondering whether to pull the heads. i do NOT want to have to pull the head after i put it all back togather
i have done:
no MIL
new
i had the same thing happening with my '99 dodge. i know it's not a yoter, but i thought i'd throw out a suggestion. i checked compression, everything checked out ok, replaced everything excepet the distributor itself with the ignition. replaced all the spark plugs three times within a hundred miles thinking they were fouling out. nope, still had cyl 1,3,8 misfiring. it's automatic and when i went up an hill or pushed the gas pedal anymore than just normal driving, my heater vents on the dash would switch to the defrost. i did some checkin, i had lots of oil in my intake manifold. so i replace the intake and plennum gaskets and the thing runs like a charm and no more misfire. no more codes. hope this helps a little, good luck gettin it fixed
ok so im stumped
i put it all back together and the miss is still there BUT i went to unplug the TPS and the miss STOOPED and there is no mill. i know this should be a nobrainer to someone that knows the 3vze. so if your out there please HELP
i got a new tps and adjusted it and the miss is still there. does any one have a wiring diagram that shows what els is interupted when it is unpluged so i can chase the prob down?
please help they messed it up it will now not rev past 3g i dont know what they did they may have messed with the ps and timing but i tried to set the timing and it is correct but when i move the distributor to the middle (were i had it set b4} it runs better
they said it "may" have a burnt #5 valve but i have done 3 comp test and they are all about 150psi
also still have that miss i ordered a coil/igni \, any sugestions would be greatly appreciated!!!!!!
could it be coil or injectors or dis
