bad bank 1 miss need help.. going crazy!!!
Old Mar 15, 2010 | 12:44 PM
drkblu4runner's Avatar
ospartier- did you mess with anything or did you one day start it up and it had the timing prob
Old Mar 15, 2010 | 07:33 PM
Exclamation
ya i adjusted the tps and that fixed it you should do the same. but i still have a bad mis so if anyone has any suggestions that would be great
also if anyone has any good pics/diagrams of the vacuum lines on the passenger side that may help also
Old Mar 16, 2010 | 09:53 AM
ospartier's Avatar
No, I bought it that way. I got a little cocky and figured I could fix anything that goes wrong with a yota. lol. Anyways, I bought a new TPS and installed it, and I think it's adjusted right. My ohm readings on IDL and E2 are 0.01ohms with a .50mm feeler guage, and infinity at .77mm. I wouldn't doubt that still being the problem but I'm just frustrated wtih trying to adjust it. If you remember. What was your ohm readings between IDL and E2 at .50mm?
Old Apr 4, 2010 | 08:34 PM
Talking Fixed
i replaced the coil/ignigtor and it runs smoother then it ever has. im guessing that it was just the ignitor.........
So now im going to wright toyota a nasty letter!!!!
Old Apr 4, 2010 | 08:40 PM
  #25
Kiroshu's Avatar
I can't believe the toyota dealer didn't think to look at the ignitor seeing as how they are a huge issue that comes to the dealer constantly... I was just about to ask you which plug wires you pulled off that had no affect in how it ran and to do resistance checks on the ignitor and coil lol. See thats a simple fix and you thought i was a burnt valve and something major. Always start small. The ignitor is like the heart of the "signal system" If its not working prob just about everything else won't. Its tricky and not one of toyotas pride and joys in design... Glad you got it fixed
Old Aug 10, 2010 | 06:40 AM
  #26
ya i have been pulling a 19' boat all summer with out any problems... sooo everyone stay away from FOLSOM TOYOTA in north ca
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
TDonkey
Jul 26, 2015 10:14 AM
