Toyota Transfer case
I am selling a Toyota, gear driven, forward shift transfer case. Installed is a brand new set of Trail Gears 4.7:1 Reduction Gears. Transfer case has yet to be bolted in the truck...Im going another route. Located in Newnan, GA 30265
$400
$400
hmmm will it fit my 93 either as a first or second case? Seems like I could use it as a second case?
It would fit, but i beleive you'll need and adapter to bolt it to your tranny. It would work as either front or rear, again w/ the adapter. http://trail-gear.com/v6-adapter.html
Hm the Trail Gear website says you need a Top shift case. Your ad says forward shift. If I knew it'd work I'm interested..
yes there are ways to modify a forward shift into a top shift. if you're still interested you can look around this board and the pirate4x4 board for a write up on how to do that.
skoti89
Jul 6, 2015 07:45 PM
toyoda8488
Jul 5, 2015 10:18 PM
