How to install trailgear ifs steering box mount
Hey guys I purchased the trail gear crossover steering assy. Where I need help is mounting the ifs steering box. I bought the mount but it doesnt come with instructions and I having trouble determing where it goes some pics would be nice if someone has used this on their rig. As usual much appreciated guys.
if you are doing new springs (you need 3" of lift to clear high steer) with a new front mount, mount your springs and axle before you do the IFS box mount--saves you having to move it again...
one of the better examples I have seen:
what you don't want to have happen when you install your high steer:
The IFS box mount is pretty simple. Cut the fender well so you can easily access the PS box area like shown in my pictures posted already and then push the box all the way forward until it is on the core. Angle it so the holes line up on the frame in the center and then test fit your mounting plates. Tack weld and test fit again to make sure the pitman arm clears and weld out.
jerusry
Oct 19, 2015 05:28 PM
rushw
Jul 18, 2015 01:46 PM
jon.r
Jul 11, 2015 03:34 PM
crashburnoveride
Jul 10, 2015 06:39 AM
skoti89
Jul 8, 2015 12:05 AM
