94 p/u speedometer probs???
Ok, first off.... 1994, 4wd, 22re, 5speed. My speedometer, nor odometer has never worked since I've owned this truck. I read some threads on here today, just came back in from checking the sensor on the tranny. The gears look fine, I was wondering if there is a way to zero out the sensor as the prob, b4 I went and bought another, OR do you guys think it may be something else, THANKS
i guess cuz its newer it has an electric spedo, im sure theres a why to test the spedo with an ohm meter or something, look through the FSM thats listed at the top of the forum, sure it will tell you how, ide look through mine but i have one for 85-
Negative, it is still cable driven.
theres wires that run all the way back from the intruments to your tranny which is where the sensor is located i had the same problem only my wires were disconnected or stripped in half however you want to put it but anyways the sensor was still good
yeah 94 is deffinetly electrical not cable i think they stopped in 89 or 90 possibly could be wrong not sure but my 93 is deff electrical you could just have a bad sensor id start with that if you see no loose conections
bryan34w
12
Sep 30, 2015 02:50 PM
Phantez
Sep 30, 2015 08:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Rickstwowheels
Sep 21, 2015 05:21 AM
