Truck has power but will not start. Help!
Old Feb 5, 2010 | 12:15 PM
cchant's Avatar
I did a quick search but couldn't find any thing and now I'm stuck. I can turn the key on and the dome light comes on and the buzzer comes on for the key in the ignition but when I turn the key over nothing happens. My dash gauges, clock and radio all quit working when this happened. When I turn the key to on nothing comes on. When I turn the key to start the truck, nothing happens at all.
This is on my 89 extended cab with 22RE
Old Feb 5, 2010 | 12:21 PM
Junkers88's Avatar
What have you checked so far?
Old Feb 5, 2010 | 12:30 PM
cchant's Avatar
All the fuses under the dash and under the hood. All batter and alternator connections. looked for loosed grounds or connections under dash and hood. It all looks good.
I have power to the head lights but no turn signals but the hazards work. Turning the key doesn't even result in a click
Old Feb 5, 2010 | 12:41 PM
allnmstkn313's Avatar
Check the starter, and check if the wire is triggering.
Old Feb 5, 2010 | 01:23 PM
Camphyak's Avatar
Have you checked the switch on the clutch pedal?
Old Feb 5, 2010 | 01:43 PM
cchant's Avatar
all wiring to starter is good and clutch switch is fine. I am getting no power to dash so I can't clutch cancel start or use the clutch to start.
Old Feb 5, 2010 | 02:21 PM
WatsonToyota's Avatar
what condition is the battery in? u try jumpin it at least?
Old Feb 5, 2010 | 03:12 PM
only other item to check really is the starter relay...
does it turn over/run if you jump the starter?
Old Feb 5, 2010 | 05:54 PM
cchant's Avatar
well I figured it out guys. I somehow managed to overlook the 80 amp fusible link I managed to blow under the hood. I'm not really sure how I did that but I was messing around near the alternator so I guess I shorted it there. I replaced that and she started right up. Thanks for the all the input guys!
Old Feb 5, 2010 | 06:06 PM
Just Learning's Avatar
hmm , good thing you found that , but are you sure nothing else went worng to blow the fuse-- be carefare,
layifioren
10
Jul 6, 2015 02:26 PM
rbravo1
Jun 29, 2015 01:34 PM
Butch35
Jun 25, 2015 07:47 PM
newzingo
Jun 24, 2015 01:50 PM
jmc88runner
Jun 18, 2015 03:39 PM
