over heats with ten mintes twice then is fine????
i have a 86 runner 22re fuel injected.... i just replace thermostat and did a coolant flush and every time i start my car from a cold start and start driving it will over heat, (then i stop and let it cool down) then i will be off again, and i will come close again. Usually after that its fine, my temp guage varies but stay good the rest of the time... i talked to a few toyota techs that said they dont think is the head gasket going.. any ideas?
hows the fan clutch? cold spots in the radiator? air in the system?
oh and corey https://www.yotatech.com/forums/f5/d.../index132.html thats our bs chit chat thread
did you purge the cooling system of all air after replacing the thermostat?
Use OEM t-stat? try replacing it with an OEM dual stage or try drilling a small (1/16 or so) hole in the t-stat.
how do i check the fan clutch? or purge the air?................i've heard of the dual stage thermo and i went to the dealer to see if they had one and they had no idea what i was talking about
I have an 87 22re and it was doing the same thing. I flushed it,t-stat and about everything else. Finally I took it to a radiator shop and they were able to flush it with high pressure and it looked like mud coming out. These radiators are old and have alot of build up in them.
Try a new thermostat for sure. Parts stores also tend to hand out thermostats for the wrong temp.
replace the thermo..
My truck was doing the same thing. I had a fresh rebuild and it kept overheating. Until I could find a Toyota two stage thermo I just drilled a small hole opposite the valve side on the parts store thermostat. It worked and my truck stopped overheating. Later I got a two stage and installed it and it works and no overheating. I've been driving it like this for over four years and the temo gauge never budges from it's normal LOW spot. I really think that this common thermostat problem is the key issue with so many 22R/E headgasket problems.
Fan clutch is a very simple and relatively cheap fix if the thermostat doesn't work out.
WTB[PacNorWest]: WTB Factory chrome fender trims 4x4
skebe22RTE
Jul 31, 2015 02:03 PM
Poncho0206
Jul 10, 2015 06:21 PM
