Sponsored by: CARiD
lift questions
Old Dec 21, 2009 | 03:49 PM
Jimbo88's Avatar
lift questions
planning on gettin a lift for my 96 t100 either a 3in body or 4in suspension what does everyone recommend? and if i put 33s in after either lift does anyone kno the overall ride height id like to have it still fit in the garage
Old Dec 21, 2009 | 04:04 PM
peow130's Avatar
Well, what size tires do you have now?
Also, body lifts are to fit bigger tires, and suspension lifts are for ground clearance.
What do you plan on doing? Lots of 4x4ing?
Old Dec 21, 2009 | 04:24 PM
85TurboRunner's Avatar
try posting this up over in the t100 section.
Old Dec 21, 2009 | 04:33 PM
camo31_10.50's Avatar
well..my '92 4runner with a 4" suspension and sittin on 33's will fit in my garage (standard size) with just an inch or 2 to spare, so i imagine yours will be the same
Old Dec 22, 2009 | 09:18 AM
brian2sun's Avatar
Suspension lifts will allow for bigger tires and more travel, body lifts will just allow for bigger tires. Either way, your clearance is always limited to the size of your tires because they determine how high the rear axle is off the ground. In an IFS truck, you'll have more clearance in the front from a suspension lift, but that doesn't matter since your rear axle (diff) stays at the same height untill larger tires bring it up.
Old Dec 22, 2009 | 09:39 AM
brian2sun's Avatar
Actually, both body and suspension lifts allow for bigger tires but neither lift alone gives you more ground clearance because that is determined by your tire size. The difference between the two lifts is a suspension lift gives you more travel.
In an IFS truck, a suspension lift will give you more ground clearance in the front only, but it doesn't matter because the rear axle (diff) stays at the same height unless you put bigger tires on to raise it. In other words, the lowest point on the truck stays the same.
Since either lift allows for bigger tires, you can get more ground clearance from either.
Old Dec 23, 2009 | 09:54 AM
Jimbo88's Avatar
i have 265 70 r17 right now but i plan on going with 33 12.50 r17 if its possible to run the stock tundra wheels i have on it right now..really im just goin for looks ive only had my truck off road a few times i use my beater for that
Old Dec 23, 2009 | 10:38 AM
brian2sun's Avatar
Yeah, you should have no problem mounting those tires on your stock wheels.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
