advanced timing issue
my friend has 85 x-cab 4wd sr5 with a 22re he advanced the timing a little it runs much better now but now when u step on the brakes it idles up and down cause the idle is a little higher than it use to be is there any way to fix that with out going back to stock timing
check the idle adjustment screw I have the same issue and found it backs itself out and gives the up and down idle you speak of I think teflon tape on it will hold it where it needs to stay I will let you know in a day or two.
do you know what the idle is at? i mean timing, sorry. being a 85 xtra cab owner myself i wouldn't be suprised this could possibly a separate issue.
yep, check that and let us know what happens.
http://www.4crawler.com/4x4/CheapTri...CheckConnector
update he never knew about the timing jumper and it was way the hell off its now set at stock but theres still something wrong with the idle it's like at 1200 with the screw all the way down
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
saphirekosmos
Jun 22, 2015 10:26 AM
