Body mount on 2001 4Runner
Old Nov 9, 2009 | 08:22 AM
AlexJet's Avatar
I bought my 2001 a month ago and when I was doing rust proofing, I mnetioned that I have worn out and cracked 3rd body mount isolators on both left and right side (the one sitting bellow B-pillar).
I have ordered those mounts from the dealer, but dealer is trying to get out of the job to do it. They just saying its more a body shop work then maintenance. I was also thinking of janging them myself or use private mechanic.
Does someone knows how to change them? Any links, images, discriptions, guidenance will be very much apprecciated.
Old Nov 9, 2009 | 09:49 AM
hross14's Avatar
They are very easy to change--i am just wondering what you paid for them?? I too am going to replace my body mounts.
All you have to do is unbolt all the cab to frame bolts which are under the door sills and using a length of 2x4 (Two" By Four") jack up the body where the body seam comes together. The suspension will unload some and then the body will separate from the frame--install mounts and the rest is the reserve of removal.
Old Nov 9, 2009 | 10:00 AM
4Crawler's Avatar
Yep, easy enough to replace those parts:
- http://www.4crawler.com/4x4/ForSale/...l#PolyBushings
- http://www.4crawler.com/4x4/ForSale/...ft_HowTo.shtml
Old Nov 9, 2009 | 11:05 AM
hross14's Avatar
I may also just go to the junkyard and see if i can grab some from the cash to clunkers program. Does anybody know which years fit which years. I.e.. do the 1996 body mounts fit all the way to 2002? I thought there was a difference so i just want to be sure.
Old Nov 9, 2009 | 11:24 AM
4Crawler's Avatar
2001-2002 are different than the 1996 and the 1997-2000 models.
Old Nov 9, 2009 | 11:39 AM
hross14's Avatar
so 1997-2000 are the same body mounts--96 and 2001-2002 are different. Thanks a bunch
Old Nov 9, 2009 | 11:43 AM
4Crawler's Avatar
Yep, the later models are 6 2-piece bushings and 4 1-piece:
'96 only have 8 mounts and the middle years are 8 1-piece and 2 1-piece:
Old Nov 9, 2009 | 04:18 PM
AlexJet's Avatar
$80 each. Need 2 (left + right), so $160
Old Nov 10, 2009 | 06:10 AM
hross14's Avatar
Alex--there should be more than two--or are you saying you only need 2?
They seem a little pricey.......looks like i might junk yard it.
Old Nov 10, 2009 | 12:27 PM
AlexJet's Avatar
I got 2 which need replacement. Altogether there are 10 mounts on the truck.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
jon.r
Jul 11, 2015 03:34 PM
skoti89
Jul 8, 2015 12:05 AM
