Jipo Work
Jipo Work
This is a list mostly for my own good but figured I would share as well in case anyone was interested.
This is a list of parts, work and status on our 1987 Toyota 4Runner 22re 5-spd prior to our S. American overland expedition.
There will be a separate post regarding our personal gear later on. I tried to keep this one directly tied to the 4runner.
This is a work in progress and will be edited accordingly.
Calexico
Jipo Work
New
Thermostat
Timing Kit
Spark Plugs
Oil Filter
Oil
Antifreeze
Radiator
Hoses
Belts
Camshaft
Upper gaskets
Air filter
Windshield wipers
Muffler
Exhaust pipe
Fuel filter
Fuel pump (in-tank)
Brakes, front and rear
Shocks (Gabriel Ultras, front and rear)
AC Evaporator
AC Expansion Valve
Rebuilt/Repaired parts
Starter (replaced contacts)
Alternator (90 amp stator upgrade)
AC Compressor
Rear window circuit (on the dash)
Starter circuit (low dash switch)
Tachometer circuit (on dash gauge)
Air compressor circuit (in engine bay, switch on firewall)
Driver side vent window (junkyard special)
Donor parts
Roof Track system
Seats
Rear seat belt females and bench belt
Rear rubber mat, cushion and carpet
Yota D-Rings (four)
Clock
Grab Handles
AC Condenser
AC Drier
Goodyear Silent Armour 31" tires
Sony head unit
Sony xPlod 4" speakers
Aftermarket Parts
Diehard 400W Inverter
Rear Deck 12v DC plug
Rear deck cutting boards
Odyssey 925 MJT battery ( I love this thing)
Blue Seas Battery Selector Switch
13' Mosquito Net
Thule Go Bin Tote (the big one)
Thule Side carrier
Thule small organizer
*Sleeping Deck
*Cargo Cover *(4) 36"x19.5" blondewood planks & (4) cedar 2x4
*Selectable mini-tables
Vehicle Status Report as of 11/6/2009
ITEM
STATUS
Vehicle Gear List
Calexico
Jipo Work
New
Thermostat
Timing Kit
Spark Plugs
Oil Filter
Oil
Antifreeze
Radiator
Hoses
Belts
Camshaft
Upper gaskets
Air filter
Windshield wipers
Muffler
Exhaust pipe
Fuel filter
Fuel pump (in-tank)
AC Evaporator
AC Expansion Valve
AC Compressor
Donor parts
Roof Track system
Seats
Yota D-Rings (four)
Clock
Grab Handles
AC Condenser
AC Drier
Sony head unit
Aftermarket Parts
13' Mosquito Net
Thule Side carrier
*Sleeping Deck
ITEM
STATUS
- Engine Oil Level
- Cooling System Hoses
- Brake Lines
- Brake Operation
- Windshield Wiper Blades
- Head Lights/Driving Lights
- Power Steering Hoses
- Exhaust System
- Parking Brake Operation
- Fan Belts
- Mirrors: Side, Rear-view
- AC functioning
- Transmission Fluid Level
- Brake Lights/Turn Signals
- Brake Fluid Level
- Tail Lights/Reverse Lights
- Power Steering Fluid Level
- Tire Wear/Inflation
- Tire Balance/Alignment
- Spare Tire (condition)
- Horn
- Anti-freeze Level
- Heater functioning
- Dual Battery Circuit
- Sleeping Deck
- Inverter Circuit
- other
- other
- other
- other
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
- SAT | UNSAT
Vehicle Gear List
- Master First Aid Kit
- Blanket
- Spare Fuses
- Hi Lift Handle All
- Engine Fluids
- Flashlight
- Flares/Reflective Devices
- Tool Kits (Master, Backup, Spare)
- Extra Belts (Main, Alternator, AC)
- Water (7 Gallon jug)
- Fire Extinguisher
- Jumper Cables
- Duct or Electrical Tape
- Non-Hi Lift Hi Lift jack
- Spare Tire
- Electrical cable (10 awg & 16 awg)
- 20' Recovery strap 3"
- 25' Galvanized Aircraft Cable 3/8"
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
