Old Feb 9, 2016, 10:50 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical Guides
Print Wikipost
22re ground wire locations - the guide!!!
Old Oct 18, 2009 | 01:03 PM
iamsuperbleeder's Avatar
Alright, the question has came up SO many times, so here's the final answer
I don't think I could make this any more simple
This wire comes right off the - terminal of the battery, and follows the + wire leading to the starter. It splits out of that harness right by the upper control arm and runs over to the engine block. On AC equipped models (as shown) this wire bolts to the AC compressor mounting bracket via one of the bolts that bolt it to the block. Without AC, I can only assume that the wire bolts directly to the block itself.
This wire is bundled in the wiring harness for the alternator. It splits off from the harness and runs up to a bolt at the rear of the power steering pump that mounts the pump to its bracket.
This ground goes DRECTLY from the cylinder head (bolts to the head using the same bolt as the engine hoist hook does), and runs right to the firewall.
This is probably the most commonly overlooked and asked about ground on the 22re. It sprouts off of the same wiring harness that runs between the upper and lower intake and has all the fuel injectors and VCV pigtails as well. It is actually 2 wires, that both bolt together at a bolt that secures the upper and lower intake together.
Hope that will help some folks out
Old Oct 18, 2009 | 01:10 PM
raydouble's Avatar
Nice
Old Oct 18, 2009 | 01:12 PM
weaselman's Avatar
awesome, thanx man. great pictures. thanx for taking the time and pictures.
i have all of those grounds hooked up, except for #3. i wonder if i should hook it up. lol
oh and if you dont have #4 hooked up, you will get a constant check engine light, at least i did. lol.
#EDIT# sticky anyone??
Old Oct 18, 2009 | 01:26 PM
mcm375's Avatar
You are the man. Thank you. SWEET JESUS THANK YOU.
Old Oct 18, 2009 | 01:33 PM
YFZsandrider's Avatar
I second that!! Just helped me out a ton!
Old Oct 18, 2009 | 05:04 PM
BigBluePile's Avatar
There's suppose to be grounds??
Old Oct 18, 2009 | 05:07 PM
kiyobrown's Avatar
All I saw was a bunch of grease, dirt, and oil leaks.......
Oh yeah and some John Madden style drawings on the telestrator. BOOM!
Old Oct 18, 2009 | 05:40 PM
ROTFLMAO!!!!!
Old Oct 18, 2009 | 06:03 PM
mcm375's Avatar
Just wanted to say THANKS AGAIN, I read your post, went outside and hooked everything up... starter fired up first time and everything electrical works
Old Oct 18, 2009 | 06:07 PM
I'm glad this post has helped so many people out already! I figured it would
Thanks for all the positive feedback!
lmao, yeah the motor was pretty dirty during the tare-down when I took all the pics the first pic is the completed motor though
and yeah, I got mad skillz in Microsoft Paint!
Thanks again guys! Glad I could contribute!
Travis
Old Oct 18, 2009 | 06:13 PM
kiyobrown's Avatar
Sorry, sorry, I forgot about the first pic Trav!
You should have shown your brake booster in the other pics though, would have made that bastard look oh so shiny and clean!!
It stands out a little too much in the pristine engine bay.
Old Oct 18, 2009 | 06:56 PM
better?
Old Oct 18, 2009 | 07:08 PM
lawl.
Old Oct 18, 2009 | 07:28 PM
lawl.
I told you, I got mad paint skillz; I can't touch up any picture
lmao
Old Oct 18, 2009 | 07:34 PM
toyota4x4907's Avatar
So whats the point of #3?. Its cut on mine and I didnt know it was a main engine ground. I was just kind of like hm, a random grounded wire
Old Oct 18, 2009 | 07:37 PM
Oh and without A/C, #1 does bolt directly to the block
Old Oct 18, 2009 | 07:55 PM
Well in a nut shell, #3 grounds right to the head, and that makes it a direct ground for the electrodes on the spark plugs. Without it, you may not be getting as strong of a spark as you could be getting with it
well good, I'm glad my assumption was right, lol
thanks!
Old Oct 18, 2009 | 08:00 PM
I see. I'll check that out tomorrow. Thanks for the thread Bleeder
Old Oct 18, 2009 | 09:27 PM
kiyobrown's Avatar
lmao
Can't deny that! But now when I see a pic of your rig, all that pops into my head now is "BOOM!"
Old Oct 19, 2009 | 01:31 PM
If #3 was not grounded, would it contribute to/cause pinging?
