22re ground wire locations - the guide!!!
7 Attachment(s)
Alright, the question has came up SO many times, so here's the final answer
I don't think I could make this any more simple :D Attachment 185126 #1 This wire comes right off the - terminal of the battery, and follows the + wire leading to the starter. It splits out of that harness right by the upper control arm and runs over to the engine block. On AC equipped models (as shown) this wire bolts to the AC compressor mounting bracket via one of the bolts that bolt it to the block. Without AC, I can only assume that the wire bolts directly to the block itself. Attachment 185127 Attachment 185128 #2 This wire is bundled in the wiring harness for the alternator. It splits off from the harness and runs up to a bolt at the rear of the power steering pump that mounts the pump to its bracket. Attachment 185129 #3 This ground goes DRECTLY from the cylinder head (bolts to the head using the same bolt as the engine hoist hook does), and runs right to the firewall. Attachment 185130 Attachment 185131 #4 This is probably the most commonly overlooked and asked about ground on the 22re. It sprouts off of the same wiring harness that runs between the upper and lower intake and has all the fuel injectors and VCV pigtails as well. It is actually 2 wires, that both bolt together at a bolt that secures the upper and lower intake together. Attachment 185132 Hope that will help some folks out :D :cheers: |
Nice :bump:
awesome, thanx man. great pictures. thanx for taking the time and pictures.
i have all of those grounds hooked up, except for #3. i wonder if i should hook it up. lol oh and if you dont have #4 hooked up, you will get a constant check engine light, at least i did. lol. #EDIT# sticky anyone?? |
You are the man. Thank you. SWEET JESUS THANK YOU.
Originally Posted by mcm375
(Post 51255833)
There's suppose to be grounds?? :think:
All I saw was a bunch of grease, dirt, and oil leaks....... :hillbill:
Oh yeah and some John Madden style drawings on the telestrator. BOOM! |
Originally Posted by kiyobrown
(Post 51255994)
Just wanted to say THANKS AGAIN, I read your post, went outside and hooked everything up... starter fired up first time and everything electrical works :D
I'm glad this post has helped so many people out already! I figured it would :D
Thanks for all the positive feedback!
(Post 51255994)
Oh yeah and some John Madden style drawings on the telestrator. BOOM! and yeah, I got mad skillz in Microsoft Paint! :banger: Thanks again guys! Glad I could contribute! Travis :cheers: |
Sorry, sorry, I forgot about the first pic Trav!:great:
You should have shown your brake booster in the other pics though, would have made that bastard look oh so shiny and clean!! It stands out a little too much in the pristine engine bay. :jk: |
1 Attachment(s)
(Post 51256066)
You should have shown your brake booster in the other pics though, would have made that bastard look oh so shiny and clean!! It stands out a little too much in the pristine engine bay. :jk: better? :D |
lawl. :roll:
(Post 51256112)
lawl. :roll:
lmao :D |
So whats the point of #3?. Its cut on mine and I didnt know it was a main engine ground. I was just kind of like :think: hm, a random grounded wire:think:
Oh and without A/C, #1 does bolt directly to the block :hillbill:
Originally Posted by toyota4x4907
(Post 51256126)
(Post 51256128)
thanks! :cheers: |
Originally Posted by iamsuperbleeder
(Post 51256139)
Well in a nut shell, #3 grounds right to the head, and that makes it a direct ground for the electrodes on the spark plugs. Without it, you may not be getting as strong of a spark as you could be getting with it
:cheers: |
(Post 51256123)
I told you, I got mad paint skillz; I can't touch up any picture :banger:
lmao :D Can't deny that! But now when I see a pic of your rig, all that pops into my head now is "BOOM!" |
If #3 was not grounded, would it contribute to/cause pinging?
