nail is stuck deep in rear driver side tire
Old Oct 17, 2009 | 09:08 AM
bak3rme's Avatar
i have a nail that is stuck in my rear driver side tire, the nail is stuck flush with the tire, it is not sticking out or anything, how do i go about pulling this one out?
also, when i get it out, should i patch or plug it?
if i plug it , that means i have to take the bolts off and take tire out, could this be bad for the car? ive done it before though
Old Oct 17, 2009 | 09:19 AM
Built2Grind's Avatar
bring it to a respectable tire shop and get it patched, plugs are temporary. it will be around $20 for a patch and your good. i have been driving with a patched tire for 2 years and it has been just fine
Old Oct 17, 2009 | 09:25 AM
algranger's Avatar
I'm running a few plugs theyve never leaked on the road or on harsh off road trails.
A plug is something you can do with the tire still on the vehicle it only takes a few minutes and is very easy.
As for the nail i would say get some vice grips and see if you can wiggle it out, maybe try getting a little dishsoap on there for lubrication if its giving you troubles
Old Oct 17, 2009 | 09:34 AM
Teuf's Avatar
I agree with Algranger DIY what joy , rapture.
Old Oct 17, 2009 | 09:42 AM
kiyobrown's Avatar
if you aren't familiar with plugs and how to do em, try this.
http://www.dynaplug.com/
my neighbor probably has 3 or 4 in each tire as he works at a door shop. no problems to date.
So simple my neighbor that doesn't even know how big his engine is can do them.
stir_fry_boy's Avatar
Pay $20 and get it fixed right and not have to worry about it.
Old Oct 17, 2009 | 10:29 AM
BajaRunner's Avatar
Discount tires does it for free if you've got one nearby.
Old Oct 17, 2009 | 12:26 PM
cpizzle42's Avatar
Been working at Discount tire for over 2 years. Dont plug it. Take it to a DT and have them patch it. The patch willl out last the tire itself. If you plug it, moisture can get past the plug, then to the steel belts, then rust forms. And that aint good. O and flat repairs are always free.
Old Oct 17, 2009 | 01:15 PM
ILLINOISYOTADAWG's Avatar
i've done it both ways never had a problem with plugs or patch its just up to what you feel
Vargntucson
Jul 4, 2015 12:15 PM
miceal383
Jun 29, 2015 12:27 AM
AustinTaco
Jun 21, 2015 09:54 AM
