small coolant leak by the top radiator hose going to the engine
Old Oct 13, 2009 | 04:08 PM
sis004runner's Avatar
i replaced the hose could this mean its the thermostat houseing that is leaking
Old Oct 13, 2009 | 08:57 PM
rjaudi's Avatar
The thermostat housing connects to the lower cooling pipe. There is a gasket under the water outlet that the upper hose connects to at the engine. It is a 4 dollar part so it may be worth looking into.
Old Oct 13, 2009 | 09:11 PM
is t a pain to do?
Old Oct 13, 2009 | 10:26 PM
raydouble's Avatar
What engine?
Got pics of the leak?
Old Oct 13, 2009 | 10:28 PM
3.4 theres a puddle on the timing cover sittng below the hose gets on the belt and squeeks
Old Oct 14, 2009 | 07:17 AM
Kerby J's Avatar
well fsm recomends that if collant gets on your timing belt that it should be replaced jus fyi
Old Oct 14, 2009 | 10:51 AM
not the timing belt the drive belts its a really slow leak
Old Oct 14, 2009 | 11:49 AM
brian2sun's Avatar
I would do a pressure test and see if you can tell where it's squirting out from. Maybe the hose fitting on the top of the engine where the top hose connects. There are 3 bolts that hold the fitting on if I remember right which if loose/corroded can cause a leak.
Spicer
Apr 7, 2026 07:17 PM
voiddweller
19
May 2, 2016 09:10 PM
noahstancik
Jul 10, 2015 11:18 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
infinityisfive
Jun 16, 2015 06:51 PM
