clutch/tranny/ shifting questions.
Old Oct 5, 2009 | 03:05 PM
516593812's Avatar
Some questions I'm curious about regarding my '90 22R PU/ 4spd/2wd
1.) When the clutch is starting to go, it will slip right?
2.) Under what circumstances/ conditions would the clutch lock up?
3.) Is it bad for the tranny to shift without the clutch? (I do it sometimes-I know what speeds I can put in which gears without any hesitation/ grinding, they slide right in, & I often pop it out of gear while decelerating without getting any hesitation/ grinding)
Thanks!
Old Oct 5, 2009 | 05:27 PM
yoterr's Avatar
if the clutch is going it tends to not grab as much when trying to start from a dead stop, and if its really bad itll slip with higher rpms and load, such as going up a hill or something
Old Oct 5, 2009 | 05:33 PM
516593812's Avatar
It slips a little when you floor it or when you give it too many RPM's uphill. How much longer do you think I have 'till it's not driveable?
Old Oct 5, 2009 | 05:34 PM
516593812's Avatar
Yoterr- do you have any answers for my other questions? You sound much more technically skilled than me!
Old Oct 6, 2009 | 11:37 AM
516593812's Avatar
Anyone???
kawazx636
Oct 6, 2021 03:03 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
Davebarbier
Nov 3, 2015 03:28 PM
Flightguy
Oct 2, 2015 05:34 PM
creecher10
Sep 30, 2015 03:27 PM
