clutch/tranny/ shifting questions.
Old 10-05-2009, 03:05 PM
516593812's Avatar
Some questions I'm curious about regarding my '90 22R PU/ 4spd/2wd
1.) When the clutch is starting to go, it will slip right?
2.) Under what circumstances/ conditions would the clutch lock up?
3.) Is it bad for the tranny to shift without the clutch? (I do it sometimes-I know what speeds I can put in which gears without any hesitation/ grinding, they slide right in, & I often pop it out of gear while decelerating without getting any hesitation/ grinding)
Thanks!
Old 10-05-2009, 05:27 PM
yoterr's Avatar
if the clutch is going it tends to not grab as much when trying to start from a dead stop, and if its really bad itll slip with higher rpms and load, such as going up a hill or something
Old 10-05-2009, 05:33 PM
516593812's Avatar
It slips a little when you floor it or when you give it too many RPM's uphill. How much longer do you think I have 'till it's not driveable?
Old 10-05-2009, 05:34 PM
516593812's Avatar
Yoterr- do you have any answers for my other questions? You sound much more technically skilled than me!
Old 10-06-2009, 11:37 AM
516593812's Avatar
Anyone???
kawazx636
10-06-2021 03:03 PM
punks_is_4x4
02-26-2016 04:29 PM
Davebarbier
11-03-2015 03:28 PM
Flightguy
10-02-2015 05:34 PM
creecher10
09-30-2015 03:27 PM
Quick Reply: clutch/tranny/ shifting questions.
