93-98 T100s All T100 trucks
t100 problems
Old Sep 21, 2009 | 09:49 PM
Matt3203's Avatar
Exclamation t100 bounces under throttle
ok so ill just start here, when i start the truck after its been sitting for a while i idles fine but as i start to drive in bounces as if i have in 5th goin 10mph and does it with every shift til i start gettin into higher rpms. i also hear some sort of grinding noise around 2.5k to 3k rpms in all gears. these problems stop once you get it warmed up.
Now the other problem is when driving for more then 10 minutes at 65mph on the highway, the engine heats up a good bit, not over-heating, just halfway on the gauge apposed to a little less then a 1/4 on the gauge. i also get a oil burning smell but only after driving highway speeds(60+miles per hour) for bout 10mins also, and then the oil light comes on when i come off the high and come to a stop.
One more problem, one the driver side of the engine bay i hear a little tap/tick noise and someone told me its probably a small header leak, but im worried its the valves goin bad.
if anyone can help me with any of these problem please do
thank you
oh and i have a 1994 t100 DX 3.0 5spd
Old Sep 21, 2009 | 10:17 PM
toyota4x4907's Avatar
When was the last time you checked the oil level?..
Old Sep 21, 2009 | 10:26 PM
Matt3203's Avatar
i checked it yesterday after noon and its was full
Old Sep 22, 2009 | 04:18 AM
Zuke79's Avatar
Does the tap/tick relate to the engine rpms or is it coming from the body?
Old Sep 22, 2009 | 04:27 AM
Matt3203's Avatar
its increases with engine rpm
Old Sep 22, 2009 | 06:20 PM
Matt3203's Avatar
anybody know what could be wrong??
Old Sep 23, 2009 | 08:28 AM
BamZipPow's Avatar
Could you shoot some video and post it?
Also, are you the original owner? If not, then the dipstick could be the wrong one. Shoot a picture of it and post it.
When was the last time you changed the oil? How much oil did you put in?
Grinding noise could be the throwout bearing. How many miles do you have on the truck?
Old Sep 23, 2009 | 03:50 PM
Matt3203's Avatar
the truck has 197000 miles, i changed the oil probably 1500miles ago. ill try and get a video tomorrow thanks for your help
Old Sep 23, 2009 | 04:16 PM
Matt3203's Avatar
Unhappy
ok so another great thing just happened, i was making a video of the engine and the engine just dies and it wont crank back up, i really hope i didnt just kill my engine
Old Sep 23, 2009 | 06:17 PM
BamZipPow's Avatar
You can git a 19mm socket with a long ratchet, put it on the crank and turn it clockwise. If doesn't turn easily....then you've probably got a frozen bearing or so...
Old Sep 24, 2009 | 03:32 AM
Matt3203's Avatar
http://www.youtube.com/watch?v=nGenRkHtgf4
well i let it sit over night and it started up, maybe it was just the fuel system, i know i probably need to change out some stuff
Old Sep 24, 2009 | 06:16 AM
BamZipPow's Avatar
The tapping sounds like valves...also it sounds like yer low on oil?
Piccies of the engine bay with various looks at the left/right sides would be helpful. Also, measure the dipstick and put up a picture of the dipstick handle. I've already seen one T-100 with the wrong dipstick.
Since it didn't crank at all last night...that would say that yer starter wasn't engaging and turning the engine over. You might want to check those starter contacts.
Old Sep 24, 2009 | 09:22 AM
Matt3203's Avatar
come to think of it, its really hard to get the dip stick back in, unless you put it in just perfect
Old Sep 24, 2009 | 09:31 AM
Matt3203's Avatar
Old Sep 24, 2009 | 10:51 AM
Matt3203's Avatar
does anyone know if its the right dipstick, cause if it aint i dont wanna drive it low on oil
Old Sep 25, 2009 | 06:25 PM
BamZipPow's Avatar
Is there a number on the stick? It would be located near the end...
According to ToyoDIY the number should be 15301-65030 and measures exactly 22" from tip to the base of the handle. I got my measurements my 1993 T-100 and confirmed the numbers and measurement.
The measurement yer showing on yer stick is about 1/4" too short...
Old Sep 25, 2009 | 06:34 PM
BamZipPow's Avatar
Could you shoot some vid with you driving it? Need to hear this grinding sound at speed/rpm.
Old Sep 25, 2009 | 07:27 PM
BamZipPow's Avatar
Just out of curiousity...how are those U-joints doing? When was the timing belt/tensioners changed last? Water pump changed as well?
Old Sep 25, 2009 | 09:44 PM
Matt3203's Avatar
yeah ill try and take a decent video of the grinding noise, but its only there sometimes
and i dont really know bout the u-joints, or water pump as i just got it bout 2 months ago
but theres a sticker that says the timing belt was changed at 164000
and im at 196000
Old Oct 1, 2009 | 04:56 AM
Matt3203's Avatar
the dipstick has that number on it
and i cant get a video of grinding noise because it stopped? i aint complaining
polo451
13
Nov 20, 2016 07:49 PM
Cabell
Jul 24, 2015 12:14 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jgwerth
Jul 16, 2015 03:23 PM
taller1
Jul 16, 2015 03:00 PM
