94 3.0 v6 vze engine timing chain
Existing timing chain did not have any marks, I looked at it under excellent lighting with a magnifying glass. New belt has one set of arrows (all placed together and point the same direction) and one yellow line, but no other marks.....
So how do I get the timing lined up. I get the parts about putting the camshaft and the crankshafts into position, but does anyone know the tooth count from the crank to the first pully?
There are at least a dozen threads on this. You don't need marks on the belt; you just need to line up the crank mark & the cam sprocket marks. Check these threads, which you can find easily with the SEARCH button:
https://www.yotatech.com/forums/f116...advice-117486/
https://www.yotatech.com/forums/f116...advice-179570/
https://www.yotatech.com/forums/f116...ey-2-a-177592/
https://www.yotatech.com/forums/f116...g-20-a-178761/
https://www.yotatech.com/forums/f116...er-3vz-181019/
https://www.yotatech.com/forums/f116...estion-118098/
The marks are more of a distraction than anything else. Don't need them. Just make sure the timing marks on the cams line up after rotating it as per the FSM.
Usually you find you are a tooth off the first time, and nail it the third time.
It will take two people to do it right, you need the four hands.
Good luck
Good luck
some drunk guy
Aug 3, 2021 06:09 PM
EatChipsNow
Sep 9, 2015 01:25 AM
