5 speed tranny
The only transmissions that can be used in both the 22RE and 3vze are the R150F (3VZE) and the R151F (22RE). If you used the R151 you will need the bellhousing from the R150F to use it behind a 3VZE. Other than that, no all the other transmissions are not compatible.
Since you have a 22RE, there are a lot more transmission out there that you can use.
Check this out...http://4x4wire.com/toyota/faq/parts/
Pedalpwr27
Aug 13, 2015 06:37 AM
Tonetrk
Aug 6, 2015 10:06 AM
Iceman4193
Jul 15, 2015 04:48 PM
