Loose steering, what parts should I replace
So my 1991 4x4 4runner has had wandering steering for a while and I'm finally going to do something about it. I know the control arm bushings are bad, and I'm pretty sure the ball joints are bad as well. I wanted to know what other parts I should pick up and replace while I'm doing the front end. The steering stabilizer is good, replaced that a with OME. Also, would replacing these parts fix the wandering steering? Thanks
I did the inner rods, outer rods, pitman arm, and idler arm on Taikowaza's rig and it was under $400 Control arm bushings and ball joints can't be $800! And Tim even bought Toyota parts!
seriously! looks like a 4x4 could almost fit between those sidewalls and the UCAs. i'm suggesting having a look at your wheel bearings as well - lots of pressure on those when your wheels stick out like that. also, what's up with that CV angle? is that pic taken while at full compression?
seriously! looks like a 4x4 could almost fit between those sidewalls and the UCAs. i'm suggesting having a look at your wheel bearings as well - lots of pressure on those when your wheels stick out like that. also, what's up with that CV angle? is that pic taken while at full compression?Last edited by Ardent; Aug 10, 2009 at 12:40 PM.
GreenLion
Jun 7, 2021 10:49 AM
voiddweller
19
May 2, 2016 09:10 PM
