Runnin hot
Old Jul 11, 2009 | 09:06 PM
Nothingbutyoda93's Avatar
Exclamation Runnin hot
22-re's runnin hot sometimes, other times not hot at all. whats my answer im thinking a new Thermostat???? and dont give me no crap about this just answer the question
Old Jul 11, 2009 | 09:09 PM
Jay351's Avatar
Does it overheat on the hwy or the city?
Hows your coolant look? Old? It should be changed every two years or so.
Old Jul 11, 2009 | 09:16 PM
Usually just daily driving like 8 miles or so today and it was almost touchin in the red
Old Jul 11, 2009 | 09:19 PM
Oh and the og owner had the radiator replaced its a Gm radiator and every month or two months i need to add some. Yeah the other night i got home. just driving about 10 mins and it was smoking somewhat. I added some fresh prestone and water but i checked the tank today when she was gettin close to the red and it was full. I think Thermo is sticking or something.
Old Jul 11, 2009 | 09:31 PM
Jay351's Avatar
OKay, first heres what I would do.
I would find a new toyota rad, swap it in. While you're in there make sure your fan clutch is working correctly.
Next, I would flush out all the old coolant (drain, fill with all water, run then drain and fill with a 50/50 mix of toyota coolant and water) and replace it.
Replace your thermostat with a toyota one (trust me, they are different for the 22re)
Next jack up the front of the truck (After filling it up with your mix), remove the rad cap and set it to hot. Run untill its at its running temp. This will burp the air out of the cooling system, a problem with toyotas.
Then see where you stand. If you constantly take it past the normal temp you will have headgasket problems. ITs a given with an iron block/aluminum head combo.
Old Jul 12, 2009 | 08:05 PM
fireman1559's Avatar
and check all your hoses and your water pump as well like stated above if it keeps overheating the slightest bit you WILL have problems with the head gasket down the road there is no dobut about it. for the water pump find the weep hole and look for coolant and for the hoses when the truck gets to normal operating temp grab them and if they are weak and or mussy feeling they need to be replaced
dbollier123
Sep 29, 2015 05:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
taraf
Sep 25, 2015 02:57 PM
LotOMiles
Sep 14, 2015 11:45 PM
anndel
Sep 10, 2015 08:50 AM
