replacing fluids, need advice
Old Jul 10, 2009 | 12:31 PM
sweet trav's Avatar
I have a 96 4runner 2.7 4cyl
What should I use for the rear end?
What should I use for the trans?
What should I use for the engine?
Just want to get some thoughts before I change them all this weekend.
Thnx,
T
Old Jul 10, 2009 | 01:31 PM
okie81's Avatar
If you wanna do it right, I'd recommend Amsoil, at least for the rear. It's pricey, but well worth it.
Old Jul 10, 2009 | 01:37 PM
sweet trav's Avatar
what about the transfer case?
Old Jul 10, 2009 | 02:07 PM
okie81's Avatar
You could convert it all over to synthetics if you wanted to, but I'm not sure how much money you're wanting to spend.
Check out this site: http://www.top4runners.com/ja/synthetic.html
Old Jul 10, 2009 | 02:52 PM
hross14's Avatar
i second AMSOIL--i had it in my old tranny from another 4runner and even after it was drained etc and sitting for more or less a year, you could still feel the film on the gears
Old Jul 10, 2009 | 03:22 PM
eddieleephd's Avatar
I second Synthetic Manufacturer recomended weights!
also Lucas heavy duty engine oil stabilizer!
Old Jul 10, 2009 | 04:32 PM
scuba's Avatar
Uhh, lets find the owners manual and read that..
Itll even tell you what you need to use..
Old Jul 10, 2009 | 04:57 PM
sweet trav's Avatar
Thanks for the suggestions guys, and thanks for being not so funny scuba(I already had the manufacturer suggestions but this is where the offroaders gather and I wanted their advice). I checked with the drive train shops where I know people and I'm going with royal purple even though its a bit much on the dollar side I figure its worth trying it at least once. We'll see what happens!
Old Jul 10, 2009 | 04:59 PM
scuba's Avatar
IIRC it all calls for 75-90 all the way around..
Old Jul 10, 2009 | 06:59 PM
finder216's Avatar
I'm running Mobil One 75/90 gear lube in transfer case & both differentials...seems to work great and have had no problems with LS in rear. I'm running Mobil One 10w30 in the crankcase, but in the transmission case I'm running B&G, because I was due for a tranny flush and that's what the shop had on hand...supposed to be good stuff though.
Been running all of the above, except B&G in tranny, for past 2k miles...smooth and cool. I went with Mobil One because it seemed a little hard to get Amsoil on short notice.
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
smthwsn357
May 1, 2024 07:28 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
skoti89
Jul 8, 2015 12:05 AM
Vargntucson
Jul 4, 2015 12:15 PM
