Timing chain?? please help, video's included!
Old Jul 6, 2009 | 11:28 AM
TrevanO's Avatar
Exclamation Timing chain?? please help, video's included!
So This is my problem, the timing done was done about a year ago. But recently it started rattleing, chattering again from the case. I figured, it might be the clutch fan bearing because this started after i washed it the night before. So i went off and payed 40 dollars for a new clutch bearing, go figure didnt fix it. So then i took both the pulley belts off started it up to decide wether or not it's the waterpump, or pulley bearings STILL rattle chatters. I'm pretty sure its the tensioner because it ONLY Chatters AT idle, anything over 2grand and its golden? Thanks guys im fresh to this site.
HERES THE LINKS TO VIDEO:
http://www.youtube.com/watch?v=vYL3h_eUjk0
http://www.youtube.com/watch?v=ERzsNha9Wfw
Old Jul 6, 2009 | 11:58 AM
TrevanO's Avatar
Exclamation Timing chain?? please help, video's included!!
So basically my timing chain was replaced a year ago but just recently started to rattle, chatter again. I think it's the tensioner even at a cold idle it rattle, chatters so im pretty sure its not the valves. Around 2grand it stops, only chatters at idle. Can someone please help me? Its an 85 toyota efi pickup extended cab.
Heres the Video Links:
First video is the first start in 2 days so its a little hesistent
Old Jul 6, 2009 | 12:41 PM
PMSmith's Avatar
Sounds like broken chain guides.
Old Jul 6, 2009 | 12:45 PM
TrevanO's Avatar
think so?
Old Jul 6, 2009 | 02:12 PM
TrevanO's Avatar
whats the best timing chain kit to get? Napa has one for 83 dollars, thats without the gaskets.
Old Jul 6, 2009 | 02:32 PM
PMSmith's Avatar
Do a search for "timing chain". There are a few videos showing a chain with broke guides. You can check it with the valve cover off. Also, the consensus seems to think that Engnbldr.com is the place to get them. I plan on purchasing from there.
Old Jul 6, 2009 | 08:50 PM
85RunnerSR5's Avatar
Is it the early or late style 22R?
Old Jul 6, 2009 | 08:57 PM
Plumbrbob's Avatar
you can just pop the valve cover and look down the timing chain hole with a flash light should answer your question
Old Jul 6, 2009 | 11:56 PM
TrevanO's Avatar
its an efi 85 stock. about 50k on the rebuild. i plan on putting pictures of it up. If i take the cover off what should i seal it with?
Old Jul 7, 2009 | 03:37 PM
Plumbrbob's Avatar
the valve cover already has a seal that is reusable just make sure it is still on when you reinstall the cover. Its your best bet to figure out hte problem pop the cover and shine the light down the hole with the chain and see if a guide is broken
Old Jul 8, 2009 | 11:05 AM
TrevanO's Avatar
thanks, yea i took it apart last night. Driver side guide was totally broken off Suprised byu the slack in the chain and that i didn't skip a tooth
Old Jul 8, 2009 | 02:58 PM
XtraSlow_XtraCab's Avatar
When you did the original rebuild... did you buy an entire timing chain kit? So far all of the ones I've seen have modified chain guides made from steel. I'm assuming you either didn't replace the guides or bought a kit with plastic guides. I can't imagine anyone still making plastic guides. Rediculous... definetly one of Toyota's bad moves (suprisingly mine are still ok and they're plastic).
Old Jul 8, 2009 | 03:05 PM
Outsane's Avatar
On my 84 I had to use plastic guides. Engnbldr does not make metal ones for my year.
Old Jul 8, 2009 | 03:37 PM
foot0069's Avatar
Here's your best source. Also great people to talk to, not many people that will take the time to talk on the phone anymore it seems. Ted will hook you up with all you need.
Jim
Old Jul 8, 2009 | 04:47 PM
matts65ss's Avatar
get it from dave
http://www.davezoffroadperformance.c....php?f=3&t=932
tell him what year he has steel guides for all years
cant beat 70 bucks with all gaskets and a steel guide
TURBOrunnerNM
Jul 22, 2015 11:01 AM
coryc85
Jul 7, 2015 04:05 AM
karbin
Jul 5, 2015 11:37 PM
ptb12
Jul 5, 2015 01:49 PM
