leaking coolant
Old Jun 24, 2009 | 12:11 PM
4runner92's Avatar
leaking coolant
so the other day my 4runner started to leak coolant from the left side of my engine and i have been putting more and more in... i cant seem to see where its leaking from? i took of the skid palte and moved the stabilizer because it was dripping over that... any ideas what it is... water pump?
Old Jun 24, 2009 | 12:33 PM
TNRabbit's Avatar
check real close around the thermostat housing and the water pump weep hole.
Old Jun 24, 2009 | 12:36 PM
4runner92's Avatar
not sure where exactly that is... im new to watercooled cars...
Old Jun 24, 2009 | 12:51 PM
4runner92's Avatar
bump!!!
Old Jun 24, 2009 | 11:56 PM
4runner92's Avatar
i tried to search but nothing,,,, anybody?
Old Jun 25, 2009 | 12:18 AM
Skoalbandit's Avatar
left side as in drivers side? Could be coming from the water pump inlet/outlet deep in behind the alternator... the gasket cracks. Get some Barrs Stop Leak, I bought the block seal, it seals all major gaskets, etc and it worked great.
Old Jun 25, 2009 | 01:57 AM
TNRabbit's Avatar
Bars WILL clog your radiator, AT LEAST....
Old Jun 25, 2009 | 04:22 AM
toyota4x4907's Avatar
DO NOT use stop a leak crap. I used it once. Fixed my leak for like 3 weeks, then I was fishing out all that crap with a chopstick. Then my radiator had a catastrophic failure......
Old Jun 25, 2009 | 04:55 AM
abecedarian's Avatar
when describing 'left' or 'right' when talking about anything on a vehicle, please give a reference point such as the intake side, or exhaust side, or 'on the left when standing in front of the truck, looking at the engine' or similar.
Saying simply either "left" or "right", or "driver's" or "passenger's", doesn't mean diddly since we don't know where you were standing, etc. or if you have left or right hand drive.
Old Jun 25, 2009 | 03:51 PM
4runner92's Avatar
sorry i mean the passengers side if that clears anything up... its leaking pretty good... i mean steady drops and it also leaks when the car is off,,,,
Old Jun 25, 2009 | 05:15 PM
desert-rat660's Avatar
its condensation from your evaporator!! could be a freeze plug. kinda hard to say
Old Jun 25, 2009 | 08:30 PM
Keith B.'s Avatar
Actually, the vehicle has only one front, one rear, one left, and one right side.
Old Jun 26, 2009 | 10:14 AM
jasonbrink's Avatar
The vehicle has one front, one rear, one PASSENGER, and one DRIVER side. To some people, especially when talking about the engine bay (since you are facing the engine from the opposite direction from driving position) it could actually have two different lefts and two different rights, depending on what way you are facing the vehicle.... But all good Toyota fans know that Toyota refers to left and right as if sitting in the drivers seat. So, passenger side and drivers side are probably the best terms to use to avoid any confusion.
Jason
Old Jun 26, 2009 | 10:35 AM
4runner92's Avatar
well this discussion of left and right doesnt help lol... passengers and i still have the bad leak... no ideas besides condensation??
Old Jun 26, 2009 | 12:05 PM
jasonbrink's Avatar
My best guess would be the water pump. There isn't really much else that's going to leak like that on the passenger side. Time to do the timing belt & associated stuff too as long as you're in there.
Old Jun 26, 2009 | 03:08 PM
heater core?
Old Jun 26, 2009 | 06:30 PM
yogi09's Avatar
your mystery leak sounds like the exact same one that I had on mine.. Mechanic found it to be the Heater Core and since it is summer right now, I dont need heat, so he took the lines off and hooked them together, waa laa, leak is gone.. I would check the heater core!!
Old Jun 27, 2009 | 02:32 AM
TNRabbit's Avatar
Got any pics?
Blamalam
Mar 12, 2022 07:34 AM
WellsR
12
Jul 31, 2015 03:27 PM
TJWilly
Jul 31, 2015 02:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
