engine light on 1995 3.4L T100, down on power
Old Jun 16, 2009 | 10:06 AM
Smurray's Avatar
I just picked up a 1995 T100 with a 5spd manual tcase and 3.4L. The check engine light is on and the engine feels down on power. It also feels kindve like its stumbling sometimes in the lower rpm range, under 2K or so... it almost makes me think its down a cylinder?
Im guessing this engine is OBDII, so i could take it to an autozone and get the code read and deleted to atleast take care of that, right?
It delivered 18mpg highway over a 250 mile trip and didnt have any heating issues or anything.
The engine has 215K miles and as far as i can tell has had no major tune up stuff. I couldnt find a sticker indicating a timing belt change, and i have no records of spark plugs/wires, etc....
So, what should i do to diagnose the engine?
Old Jun 17, 2009 | 04:20 AM
Smurray's Avatar
update: got the code checked out and OBD says cylinders 1 and 5 arent firing. Im going to pull the plugs and start there, work my way back to the coils and see what isnt getting juice...
Old Jun 17, 2009 | 04:22 AM
Team420's Avatar
YA... I bet its just plugs/wires/cap rotor.... just giver her a tuneup and see what happens.
Old Jun 17, 2009 | 08:20 AM
Smurray's Avatar
well it wouldnt be cap or rotor, as far as i can tell these engines are distributorless. It looks to me like there are three coil packs, 1 for every 2 cylinders, on the passenger side of the engine.
Old Jun 17, 2009 | 12:17 PM
Adam F's Avatar
Yes, distributorless.
3 Coil packs give sparks to 2 cylinders each. first pack powers #1 and #2 cylinders, second #3 and #4, third #5 and #6
When the coil packs go out, they quit sparking on both cylinders they control.
So, since yours is 1 and 5, it is not likely a coil pack issue.
Start with plugs and wires. That fixes most misfire issues.
Get NGK 3967 plugs, and NGK 4412 plug wires.
Old Jun 17, 2009 | 05:08 PM
Smurray's Avatar
Got the plugs and wires today. Did a complete oil change w/ filter while i was at it. One of the spark plugs i removed had no prong on it... it wasnt pretty.
Regardless, i threw everything together and it started right up and it purrs like it should. I cant believe how well it responded to the oil change and plugs/wires. I took it for a brief spin and no more hesitation, tons more balls, and a much smoother growl.
Thanks!
Old Jun 22, 2009 | 10:28 PM
Adam F's Avatar
Awesome! Plugs/wires solves a misfire most of the time.
What plugs/wires did you go with?
Old Jun 26, 2009 | 07:56 AM
Adam F's Avatar
Dont use Bosch plugs on ANY motor. I've had to pull broken Bosch's out of a few Hondas.
sonic concepts
Aug 16, 2025 03:13 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
Dr. Evil
Jun 7, 2002 09:19 AM
