33x10.5s on stock 90' pickup?
Old Jun 12, 2009 | 06:56 AM
BeNoC's Avatar
I have a stock 1990 toyota pickup xtra cab v6 5spd and i was wondering if 33x10.5s will fit on my truck without rub, i have the stock rims, and would i be better off changing gears? if so which ones? thanks
Old Jun 12, 2009 | 08:08 AM
Lumpy's Avatar
You should be alright, I'm running 31x10.5 and have plenty of room. I have 33x12.5 on my runner and they rub a wee bit when flexed (well as much as an IFS will). They do tuck in the rear and plenty of room in the front.
Check these out:
https://www.yotatech.com/forums/f116...-guide-155339/
https://www.yotatech.com/forums/f116...inside-182510/
Old Jun 12, 2009 | 05:26 PM
KVRunner's Avatar
I just put 33X10.5 BFG MTs on my runner today. I do not have any issues with rubbing. The front has plenty of room and the rears tuck very nicely. And that is with no lift at all.
Old Jun 29, 2009 | 06:59 AM
crafthorse's Avatar
KV, did you put you 33s on stock wheels or do you have aftermarket wheels?
Old Jun 29, 2009 | 07:03 AM
89silverpu's Avatar
You will need to do some trimming of the pinch weld and bottom of the fenders to clear at full stuff and lock nothing major or really noticeable though
Old Jun 29, 2009 | 07:11 AM
crafthorse's Avatar
I have the front cranked at 1-3/4", do you think I will still have to do some cutting? If I do its no biggy, ill do it.
Old Jun 29, 2009 | 08:12 AM
[N8]'s Avatar
Did you relocate your bumpstops? If not, then they will rub the same as stock at full compression.
Old Jun 29, 2009 | 01:06 PM
Jay351's Avatar
They will fit on stock rims.
The problem is your rim spacing. If you keep your stock rims, or rims of the same backspacing (4.75") then the wheel sits inside the wheel well. Now if you go to an aftermarket wheel with a spacing such as 4" bs, then the tire will stick out of the wheel well and contact the inner fender pinch weld.
I rub heavily on that area because of my rims being 3.5" backspacing...
Old Jun 29, 2009 | 04:17 PM
KVRunner's Avatar
I am running stock sr5 aluminum wheels.
kazuya2416
Apr 5, 2024 02:17 AM
lledwod
Aug 30, 2016 01:03 PM
Sep 4, 2015 09:27 AM
garagespace
Jul 9, 2015 08:37 AM
Nickdigg
Jul 7, 2015 06:04 AM
