Looking for a clutch
Old May 28, 2009 | 08:11 AM
kcpanages's Avatar
I need some help. i have a 85 yota 22r manual with 9" suspinion with 15/38.5x16 boggers. Im running 5.29 gears with full spool piece front and rear. im new to the yota but been mudding with a chevy for over 10yrs. just kinda clue less on what to get. i found this http://www.trail-gear.com/clutch.html Are they any good? also i have looked at the center force. just kinda clueless. any help would be great full.
Kris
Old May 28, 2009 | 10:30 AM
oldgold3vze's Avatar
I'd just put a new OEM clutch in it. I'm running a similar setup to you, 40s, 5.29, spools, etc, and I have had good luck with stock clutches. Plus, they're cheap.
Old May 28, 2009 | 10:37 AM
TOYOTA 1's Avatar
check this one out http://www.marlincrawler.com/clutch/...ch-kit-1200-lb i love it!
Old May 28, 2009 | 11:04 AM
drew303's Avatar
Originally Posted by TOYOTA 1
I have the marlin clutch too. It's worked well for me over the years. I recently had it off (motor out) and there was only minimal heat brazing on the pressure plate and flywheel after 3 yrs of abuse, bout 40k miles about.
Old May 28, 2009 | 07:45 PM
kcpanages's Avatar
well i believe ill spend the extra few bucks and get a Marlin.......... Thanks yall
Old May 29, 2009 | 07:02 AM
slabcrawler's Avatar
You might also consider a LUK clutch. They sell them as a kit with TO bearing, PP and disk with alignment tool. Search online for the best price. It's called a LUK Pro Gold. Bottom line is the Marlin one is great, Luk great stock Toyota great. Just get the cheapest one.
PS don't forget to surface your flywheel.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
